Fixing powered antenna on 4th gen lude
Old Feb 22, 2005 | 06:19 PM
txl146's Avatar
Default Fixing powered antenna on 4th gen lude
Power antenna is in need of replacement. It is stuck and does not go up or down. It just makes this weird noise...
Would Best Buy or Circuit city have replacement powered antennas? Thanks!
Old Feb 22, 2005 | 06:59 PM
kulrevon's Avatar
Default Re: Fixing powered antenna on 4th gen lude (txl146)
I know there was a topic a few weeks ago on this and ebay or s2000 antennas.
why do I always end up doing a search for people. LEARN HOW TO SEARCH. little button in theupper righthand corner that says search.
this is one of many i came up with
https://honda-tech.com/zerothread?id=1129273
Old Feb 22, 2005 | 07:44 PM
dmxsoulja3's Avatar
Default Re: Fixing powered antenna on 4th gen lude (kulrevon)
ebay has 4th gen replacements all over
Old Feb 22, 2005 | 07:52 PM
The Phil's Avatar
Default Re: Fixing powered antenna on 4th gen lude (dmxsoulja3)
search ebay, i've seen billions. If you want to wait it out i'm taking mine off when I get around to getting a friend of mine to weld and bondo the hole.
Old Feb 23, 2005 | 10:11 PM
Synthead's Avatar
Ditto. Ebay. Might not be Honda but there sure are a lot of em for a good deal!
Old Feb 24, 2005 | 08:41 AM
Knightmare69's Avatar
Default Re: (Synthead)
I just ended up replacing my friend's power antenna with a regular antenna that has a removable mast. Unfortunantly, the removable mast was finally removed by some thief. But the Antenna no matter what you get (Power or manual) is really tall, this is because it needs to clear the roof for signal. So you can either replace it with a power or manual version or you can retrofit one from a Lexus IS or S2000 and fill the original antenna hole.
Decatur Racer
Feb 2, 2009 06:08 PM
taunt_spike
Aug 30, 2005 08:11 PM
Turbo-GSR1287
Apr 11, 2005 12:10 PM
RUBZERK
Dec 28, 2004 11:09 AM
thehammer
Jan 26, 2004 06:55 AM
