m&h on bogarts install question
Old Feb 22, 2005 | 06:13 PM
2k.civic.si's Avatar
Default m&h on bogarts install question
i got extended wheel studs from arp for my car to be able to run these slicks....but someone told me i didnt need to change the studs that there was extended lugs that went through the wheel?
Old Feb 22, 2005 | 07:47 PM
Group Tenacity's Avatar
Default Re: m&h on bogarts install question (2k.civic.si)
You do need extended wheel studs, and you need to use the lug nuts where the shank goes threw the wheel... Bogart has lugnuts that work perfectly on their wheels as well as other racing wheels...
Mike...
Old Feb 22, 2005 | 07:49 PM
John221's Avatar
It would be better if you had extended wheel studs. It's not absolutely needed but you are much safer with them. The lugnuts are extended but they only grasp like 1/4 of the tread when using stock studs. Go with the extended studs, because it'll grasp 100% of the stud.
ricehead
Nov 18, 2009 05:41 PM
Kenzo206
10
Mar 23, 2009 10:05 PM
Midori Green
15
Jan 1, 2008 10:39 PM
TSAngry
Nov 8, 2007 01:57 PM
9seccivicsi
Jan 7, 2004 05:55 PM
