Brake problems, Help please. Brake drum help needed too
Old Feb 22, 2005 | 06:12 PM
RedDC5's Avatar
Default Brake problems, Help please. Brake drum help needed too
K, my brakes are a bit squishy, but ok. I heard that it could be the brake booster, just seeing if anyone would know. The problem comes when I come to really push down on the brakes. There is a weird feeling in the pedal, like a bumpy feeling, granted its not ABS or anything, just like the pads arent gripping or something. Does anyone think that it could be the brake drums in the back? I havent had the shoes replaced. Also, can anyone tell me how to replace my own components in the brake drum?
Old Feb 22, 2005 | 06:22 PM
eK9aT10pSi's Avatar
Default Re: Brake problems, Help please. Brake drum help needed too (4door_ridin)
how many miles. have you tried bleeding the system ? replaced pad, rotors warped?
Old Feb 22, 2005 | 06:24 PM
Donkey85's Avatar
Default Re: Brake problems, Help please. Brake drum help needed too (eK9aT10pSi)
the best piece of advise i can give u is buy a chiltons manual for the car. if you have never worked on the rear drums then u will get lost pretty quickly
Old Feb 22, 2005 | 06:28 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_ridin &raquo;</TD></TR><TR><TD CLASS="quote">K, my brakes are a bit squishy, but ok.</TD></TR></TABLE>
Sounds like you need a bleed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_ridin &raquo;</TD></TR><TR><TD CLASS="quote">. There is a weird feeling in the pedal, like a bumpy feeling, granted its not ABS or anything, just like the pads arent gripping or something. </TD></TR></TABLE>
Could be warped rotors. Pedal pulse is almost always a warped rotor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_ridin &raquo;</TD></TR><TR><TD CLASS="quote"> Does anyone think that it could be the brake drums in the back? I havent had the shoes replaced. Also, can anyone tell me how to replace my own components in the brake drum?</TD></TR></TABLE>
Probably not, it's most likely your fronts, change the pads and rotors. Every car I've had has gone over 100K before needing the shoes replaced, and that's with hard driving and track time. My mom's civic had 280K on it when the engine went from oil starvation, and the rear drums were never touched.
Old Feb 22, 2005 | 06:30 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Brake problems, Help please. Brake drum help needed too (Donkey85)
If your serious about working on your honda, you should buy a Helm Manual. They make the books that honda's service department use. Granted it costs more ($70 for helm, and $15 for chilton), but its 1200 pages dedicated to your year make & model. Chilton is more general, and only quotes specs from the Helms manual.
Best $70 I ever spent...
http://www.helminc.com
98GreenTegGSR
Dec 5, 2005 11:04 AM
HATCHingMN
Feb 24, 2004 09:17 PM
JDM TypeR 307
Feb 24, 2004 08:30 AM
AgentJam
11
Oct 15, 2003 05:50 PM
GQ Cowboy
Jul 25, 2002 06:06 AM
