Need some help Converting from Obd2-Obd1
Old Feb 22, 2005 | 04:56 PM
FOrSfEd's Avatar
Default Need some help Converting from Obd2-Obd1
I'm helping my friend switch from obd2-obd1. He has a 01 Accord running a h22a4. I figure the easiest way to go is to run a jumper obd2-0bd1 harness and a p13 ecu. the question is, what obd2-obd1 harness do we use. The A or B.
Thanks in advance.
Lee
Old Feb 22, 2005 | 07:19 PM
hotaccord243's Avatar
Default Re: Need some help Converting from Obd2-Obd1 (FOrSfEd)
the obd2b ecu uses the left 3 plugs when you look straight at the ecu,
the obd2a ecu uses the first one on the left and the far right 2.
if you look at your ecu you will be able to tell if it is A or B in which plugs it uses. the 01 ecu (correct me if i am wrong) should be the obd2b
hope that helps and good luck
Old Feb 23, 2005 | 02:49 AM
Eddiebx's Avatar
yes 01 accrod is obd2b
Old Feb 23, 2005 | 03:12 AM
FOrSfEd's Avatar
Default Re: (Eddiebx)
thanks for the help guys
Old Feb 23, 2005 | 06:16 AM
FOrSfEd's Avatar
Default Re: (FOrSfEd)
I also had one more question. If we get the jumper obd2b-obd1 harness, can we just put in a USDM P13 ECU with no problems. Meaning would the car run right just by doing this. I don't know what the differences in the newer h22a4 and the olders ones as far as red line and power is concerned.
Old Feb 23, 2005 | 06:28 AM
Blown90hatcH's Avatar
OBD2b to OBD1 conversion harness. My harnesses function properly both USDM and JDM ecus.
https://honda-tech.com/zerothread?id=997093
Jason
Old Feb 23, 2005 | 08:58 AM
if you use a jumper harness for the conversion you shouldn't have to do anything else for it it should work just fine
Old Feb 23, 2005 | 10:32 AM
FOrSfEd's Avatar
Default Re: (hotaccord243)
thanks for all the replies guys I really appreciate it.
Old Feb 25, 2005 | 06:38 AM
NoVALude's Avatar
Default Re: Need some help Converting from Obd2-Obd1 (hotaccord243)
Quick question to add here:
I have a cylinder head from a 99 and am looking to buy an H22 block (preferably OBD1, since the H23 block in my Lude now is OBD1), but if I can only find a block from OBD 2, I will need the harness and an OBD2 ECU as well right? Plug n play is the idea, but if I have to go from OBD1 to OBD2, how tough is that?
Old Feb 26, 2005 | 12:12 PM
Default Re: Need some help Converting from Obd2-Obd1 (NoVALude)
going from obd2-obd1 is basically the same concept i believe is that you can also get a harness for going the opposit way as the other guy is going, you just need a harness, but you have to know which obd2 you are going to tho,
hope that helps
LSVTEC_ALLMOTOR
Dec 21, 2004 12:05 PM
tuan...
Jan 4, 2004 08:07 PM
Renegade
Aug 29, 2003 09:17 AM
stizzit
Nov 18, 2001 01:09 AM
