Car mysteriously died..............
Old Feb 22, 2005 | 03:29 PM
Ninety5Ex's Avatar
Default Car mysteriously died..............dizzy or main relay
Driving around 30 mph my tach drops dead kinda like when timing belt broke. I used my auto club to tow back to the shop where they did the timing belt. Turns out that wasn't the problem.
The guys says to leave it and he'll tell me tomorrow what was wrong. I thought "car with these guys + overnight = **** up something and rape this kid". I demanded they tell me what is wrong because when I went with the tbelt they were happy to diagnose in a minute.
There was no spark so they say maybe it's the dizzy or the main relay. All of a sudden they can't narrow my problem unless they have the car to themselves.
I called auto club and brought car home.
How can I tell if it's main relay or dizzy? Will the main relay from my other civic 2000 VP work in 95 EX
Modified by Ninety5Ex at 4:45 PM 2/22/2005
Old Feb 22, 2005 | 03:45 PM
Ninety5Ex's Avatar
Default Re: Car mysteriously died..............dizzy or main relay (Ninety5Ex)
bump for help
Old Feb 22, 2005 | 03:49 PM
RangerDan's Avatar
check the numbers on the relay and see if theyre the same or call up your local Honda dealership and get the part #s for both.
Hopefully its just the main relay.
Old Feb 22, 2005 | 04:03 PM
Ninety5Ex's Avatar
the main relay is above the fuse box right?
Old Feb 22, 2005 | 04:10 PM
Ninety5Ex's Avatar
any ideas on pinpointing dizzy or relay?
Old Feb 22, 2005 | 04:11 PM
RangerDan's Avatar
Default Re: (Ninety5Ex)
Main relay is in the engine compartment.
Old Feb 22, 2005 | 04:20 PM
Ninety5Ex's Avatar
****** mechanic told me it was under dash
Old Feb 22, 2005 | 04:32 PM
Ninety5Ex's Avatar
how to tell? main relay or dizzy?
Old Feb 22, 2005 | 04:37 PM
civicboisi's Avatar
tach dropped dead...you tried cranking it...turns, but not over? Sounds like dizzy...same ol' shiets happend to me. The ignition coil went bad in mine I had problems since the new one and i recommend getting a OEM dizzy or one from Distributorking.
Old Feb 22, 2005 | 04:46 PM
Donkey85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninety5Ex &raquo;</TD></TR><TR><TD CLASS="quote">****** mechanic told me it was under dash</TD></TR></TABLE>
Old Feb 22, 2005 | 04:48 PM
Donkey85's Avatar
well that "******" mechanic is correct it is under the dash by left side kick pannel by the fuse box. dont believe everyone u talk to on here cuz there is a lot of false info on here too
Old Feb 22, 2005 | 06:15 PM
civicboisi's Avatar
Default Re: (Donkey85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">
well that "******" mechanic is correct it is under the dash by left side kick pannel by the fuse box. dont believe everyone u talk to on here cuz there is a lot of false info on here too</TD></TR></TABLE>
i wouldn't agree fully on that...that's why this is a forum...but technically there is TWO different fuse boxes...he probably just gottem mixed up...
but seriously...check your distributor
Old Feb 22, 2005 | 06:22 PM
Donkey85's Avatar
Default Re: (civicboisi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi &raquo;</TD></TR><TR><TD CLASS="quote">
but seriously...check your distributor</TD></TR></TABLE>
with that being said thats fine and dandy that there is a another fuse box under the hood but thats not where the main relay is loacted
Old Feb 22, 2005 | 06:24 PM
Ninety5Ex's Avatar
I just got a PDF civic repair manual and it's says there are 2. It says samething about fuel main relay then blah blah blah. I guess the ****** was a ****** after all.
hinterlander
Jun 22, 2009 03:28 PM
vargas
Sep 3, 2008 04:27 PM
rocaveli
33
Jul 13, 2005 03:16 PM
SOHCwarrior
Jul 4, 2005 05:40 PM
