Honda S2000 Honda S2000
Wheel Offset for SSR professor
Old Feb 22, 2005 | 02:42 PM
Blazeone's Avatar
Default Wheel Offset for SSR professor
Hey i just ordered a set of 19*8 +49 offset, and 19*9.5 +55 offset for my 2000 S2000. Is this the correct offset? This is what tirerack reccomended to me
Old Feb 22, 2005 | 03:00 PM
papa5murf's Avatar
Default Re: Wheel Offset for SSR professor (Blazeone)
yes thats what tirerack sells they will work.. however if you are dropped you might rub... might be wise to roll your fenders for a little more clearance... and you'll have to select the proper tire.... 19's are going to look huge on the car...
Old Feb 22, 2005 | 03:05 PM
Blazeone's Avatar
Default Re: Wheel Offset for SSR professor (03s2kblue)
Yea, well i have a veilside body kit on the car..... Just need something to fit in the fenders.
The car is lowered on KG/mm Springs...
Old Feb 22, 2005 | 03:27 PM
papa5murf's Avatar
hummm.. you're gonna rub if you're lowered on kg/mm springs.... make sure you get narrower tires... to minimize the rubbing.... and you might have to get a really aggressive alignment... so you'll be replacing tires pretty often..
Old Feb 22, 2005 | 03:39 PM
Blazeone's Avatar
So roll the fenders?
I gotta find that tire calculator to check my overall OD. IS it going to rub all the time or just on cornering?
Old Feb 22, 2005 | 03:53 PM
Blazeone's Avatar
found the tire calc
from 225/50-16F and 245/45/16
to
225/35/19F and 265/30/19R
the overall diameter difference is 0.3" in the front, and 0.6" in the rear. so i wouldnt iamgine that it would be that different, they are less than 1/2" diameter.
If i go to a 255/30/19 the total overall difference would be 0.3". Didnt buy tires yet, still dont have enough $$ left. Thought id snap up the last few sets of SSR's.
Old Feb 22, 2005 | 04:16 PM
boostdd's Avatar
wow 19s , do you have to run a 30series tire ?
Old Feb 22, 2005 | 04:56 PM
importluvvv's Avatar
Default Re: (boostdd)
30 series will be expensive but it'll give the tire a stretched look on the rims
papa5murf's Avatar
you should roll the fenders regardless of which tires you get.. since you are going wide...... as for rubbing i'm not sure exactly how much you'll rub.... you won't really know till you put it on your car and seee how it goes with those springs and such..
Old Feb 22, 2005 | 05:08 PM
Default Re: (03s2kblue)
true, you should get your fenders rolled
Old Feb 22, 2005 | 05:16 PM
Nishant's Avatar
Default Re: (importluvvv)
with only kg/mm springs, you will rub without modifying (ie fender roll)
bbRedSi
Honda Civic (2006 - 2015)
May 6, 2007 11:38 PM
vizions
Acura NSX
May 22, 2006 06:15 PM
XX Boosted Si XX
Sep 2, 2005 10:40 PM
BlazinITR
Feb 10, 2003 06:55 PM
