camp1320 header
Old Feb 22, 2005 | 12:39 PM
thegrayghost's Avatar
Default camp1320 header
Anyone running this header? Power gains? Quality? thx
Old Feb 22, 2005 | 12:41 PM
camp1320.com's Avatar
Default Re: camp1320 header (thegrayghost)
which header are you talking about..?
Old Feb 22, 2005 | 01:11 PM
hitvtecgetloud09's Avatar
Default Re: camp1320 header (camp1320.com)
for camp1320 i was there yesterday pickin up **** for my lsv good pplz
Old Feb 22, 2005 | 01:58 PM
2k.civic.si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegrayghost &raquo;</TD></TR><TR><TD CLASS="quote">Anyone running this header? Power gains? Quality? thx</TD></TR></TABLE>
i think he means this one
Old Feb 22, 2005 | 02:03 PM
thevanitygroup's Avatar
Default Re: camp1320 header (2k.civic.si)
Isnt that a PRO-FAB or PRO-FAB copy header?
Old Feb 22, 2005 | 02:26 PM
Combustion Contraption's Avatar
That is a pro-fab, its a copy of the smsp, i believe. Not bashing, they openly state this in the product description.
Old Feb 22, 2005 | 02:59 PM
Default Re: (LsVtec92Hatch)
PRO Fab Sms style "killah" Headers
Street / Race headers. available for LS / B16 / Type R / GSR applications. one of the best headers out on the market comes jet coated for less heat. 2.5 " collector gains the most HP. dyno tested and proven to work! These are headers similar as used in Jerry Built street / race beasts.
$495 shipped
Old Feb 22, 2005 | 03:15 PM
allm0t0rsir's Avatar
Default Re: (2k.civic.si)
i have seen this head make some good hp
Old Feb 22, 2005 | 03:47 PM
Yes, this is the one I am talking about. Looking at the flange, does it bolt directly to the stock/aftermarket exhaust flange location, eliminating the need for a cat or test pipe? I'm liking the ground clearance capabilities. Does anyone have actual numbers or dyno plots? Thanks
Old Feb 22, 2005 | 04:54 PM
Almtrhb's Avatar
Looks like a Smsp copy Except for the flange.
Old Feb 22, 2005 | 04:59 PM
hayabusa160's Avatar
i have this header. worked pretty good.
i wished i took pics of the ports inside the header. the welds stick out. i think if i took a rotary tool and cleaned it up i would see more gains. i'll see then its warmer out i might try it out.
you will need to have a flex pipe put in or something so you dont run a risk of cracking this header. caz theres no flex joint like oem style just a flange.
details on my motor here
https://honda-tech.com/zerothread?id=1080674
Old Feb 22, 2005 | 05:19 PM
Default Re: camp1320 header (hayabusa160)
the bung for the o2 sensor was pretty far way so i had to extend the wires for the o2 sensor to reach. but if you buy a ngk replacment from like sparkplugs.com it comes with plenty of slack so it plugs in and no worries about splicing and ****.
this header heats up fast!! it dont take long after starting the car you can feel the heat coming from the header if you stick your hand over it.
the piping is alittle in the thin side it was alot lighter then my jdm dc sports header and also alot longer.
reason i have one and sold my brand new jdm dc sports one was of the fact that this header layout in general usually shows good gains. i figure if i pay 250(thanks titanmotorsports ) for the jdm dc sports header its going to get dented and all fucked up in a few months why not spend alittle more and get a header that will show bigger gains and better ground clerance.
i pay 420 shiped for this header from sparkracing. when it first came out. i dunno if you can still get that price or not prolly not i dunno...
im running a fluidyne so i had to trim this area it might not be so bad if you have a stock rad
it hugs the oil pan its basically touching it. gettin the header in there was a bitch. i had to take my ac compressor off to clear it. i had to take one bolt off the flywheel cover and the front lower bracket( the one that bolts to the motor to the tranny) so it will clear.
took some screaming, kicking, and stuff to get it in there
i was driving around to work and etc. open header for 2 weeks on a stock oem b16 header. and i got this header soon as i bolted it on and took a drive i felt gains all over. but that was the butt dyno so i dunno. and the stock b16 header is hella restrictive...
Old Feb 22, 2005 | 06:23 PM
RMF
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote"> one of the best headers out on the market comes jet coated for less heat. 2.5 " collector gains the most HP. dyno tested and proven to work!
So is this just your opinion?I'm curious why would the 2.5" collector make the most power.Its not a 4 into 1 is it?Because if it is. A 2.5" collector is to big.Also a merge collector would make a few ponies more.
Old Feb 23, 2005 | 12:57 AM
Default Re: (RMF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">
So is this just your opinion?I'm curious why would the 2.5" collector make the most power.Its not a 4 into 1 is it?Because if it is. A 2.5" collector is to big.Also a merge collector would make a few ponies more.</TD></TR></TABLE>
my opinion? nope....that was a quote taken DIRECTLY from camp1320's website
Old Feb 23, 2005 | 10:09 PM
Default Re: (RMF)
We have been selling over 50 headers in the past 6 months.. they have great hp for the buck... no complaints ... We have tested them agaisnt hy-tech and lost 6 hp but for the $$$$ it did its job. We have a new header we have been testing that made 12 more than the hy-tech.. WATCH OUT..!! coming soon. dyno numbers will be posted soon.... too much work and not enough time. We have nothing to hide. the price is down to $425 shipped and we stock plenty of them.
Old Feb 24, 2005 | 06:18 AM
Lip's Avatar
Lip
Default Re: (camp1320.com)
contact the admins when you want to sponsor this site. NO PRICING. This place is for technical information...not a forum for you to make money.
If anyone wants that header? you know where to find them
994door
16
Oct 25, 2007 07:37 PM
Jaysun
Mar 6, 2005 12:01 PM
dkim48
Honda S2000
28
Feb 9, 2005 10:17 PM
POE
20
Jan 30, 2004 11:15 AM
slyph777
11
Aug 13, 2003 09:20 AM
