(searched) swapig in my LS motor into my new del sol? quick links?
Old Feb 22, 2005 | 11:51 AM
murmur9's Avatar
Default (searched) swapig in my LS motor into my new del sol? quick links?
Hey, I searche....but I came up with just LS motors or something for sale off a del sol. Does anyone have any link to what I'll need. the 'slow' is s 92. this is a 91 ls motor im gonna drop in. What mounts will I need to use?
and....the del sol is automatic. can i use all of my tranny pebals....hard lines...master and slave cylinder on the sol off the acura LS?
TIA
Old Feb 27, 2005 | 12:02 PM
dohcVTECeg2's Avatar
Default Re: (searched) swapig in my LS motor into my new del sol? quick links? (murmur9)
huh?!?
Old Feb 27, 2005 | 01:34 PM
ProjectGSRHatch's Avatar
You got to be clear with what you are saying, it's jiberish and I don't speak that.
Old Feb 27, 2005 | 03:24 PM
SwappedTURBOegg's Avatar
you will need a hydro transb trans not out of a 91. a clutch pedal rack out of a eg all nessary lines and master cil..you can use the mounts out of a teg maybe...but a b16 sol forsure,one modre thing is when you use teh 91 motor you need to swap teh driver side mount to a delsol b16 mount.
Old Feb 27, 2005 | 05:24 PM
HuffRacer's Avatar
Default Re: (searched) swapig in my LS motor into my new del sol? quick links? (maybewhenimdead)
I am also swaping a LS into my del sol and i was told that the tegra mounts may work. But if not the del sol B16 mounts will work.
Old Mar 1, 2005 | 01:08 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (searched) swapig in my LS motor into my new del sol? quick links? (HuffRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HuffRacer &raquo;</TD></TR><TR><TD CLASS="quote">I am also swaping a LS into my del sol and i was told that the tegra mounts may work. But if not the del sol B16 mounts will work.</TD></TR></TABLE>
integra mounts WILL work. del sol VTEC mounts are the same thing basically. BE SURE TO GET THE DEL SOL VTEC SHIFT LINKAGE.
Old Mar 2, 2005 | 05:21 PM
Default Re: (searched) swapig in my LS motor into my new del sol? quick links? (AzntaggeR)
civicgsrb18
Oct 25, 2009 04:22 PM
671sol
Feb 2, 2007 05:46 PM
soulforce
May 16, 2006 09:15 PM
ShortbusEK
May 4, 2002 01:21 AM
