Painting door panels question..
Old Feb 22, 2005 | 11:35 AM
SIcivicHATCH's Avatar
Default Painting door panels question..
I am in the process of painting my door panels and sanding them down until they are smooth. Has anyone had the problem that the door panels stay sticky. I let them sit overnight by a fan and they are still a little tacky. Any tips on drying the door panels? Also I did use vinyl adhesive promoter.
Old Feb 22, 2005 | 11:47 AM
2hatchs's Avatar
Default Re: Painting door panels question.. (H22siCivic)
WHAT KIMD OF PAINT DID YOU USE????
Old Feb 22, 2005 | 11:50 AM
Default Re: Painting door panels question.. (2hatchs)
I am using dupont sandable primer.
Old Feb 22, 2005 | 12:07 PM
2hatchs's Avatar
WITCH ONE? DOES IT HAVE AN ACTIVATOR? HOW LONG DID YOU WAIT BETWEEN COATS AND HOW MANY COATS? WHAT TEMP ARE YOU YOU SPRAYING IN?
Old Feb 22, 2005 | 12:24 PM
yes it has an activator i waited a good hour between each coat and the temp I am working in is about 74 degrees I am painting in my basement considering it is like 20 degrees outside
Old Feb 22, 2005 | 12:40 PM
2hatchs's Avatar
MAKE SURE YOU MIXED IT RIGHT BECAUSE NOT ENOUGH ACTIVATOR COULD CAUSE IT TO STAY TACKY. YOU CAN ALSO USE A FAST REDUCER TO SPEED UP THE DRING TIME. BUT YOU MUST BE SURE YOUR TEMP IS ABOVE 56 DEGREES BECAUSE THE ACTIVATOR WILL NOT WORK IF NOT.
Old Feb 22, 2005 | 12:44 PM
it is now tacky though on the door panel what should I do since it is already painted on the door panel?
Old Feb 22, 2005 | 01:22 PM
2hatchs's Avatar
USE A STRIPPER FOR PLASTIC BUMPERS TO TAKE THE PAINT OFF AND START OVER. IT WILL EVENTUALLY DRY BUT COULD TAKE WEEKS. SO I WOULD START OVER.
Old Feb 22, 2005 | 03:11 PM
ok thanks alot for the help!!!
/thread
braass91
Jan 4, 2008 09:08 AM
ichiban00
Jul 23, 2004 06:14 AM
B16X
Apr 19, 2004 05:23 AM
chris3385
Oct 13, 2003 11:34 AM
