Will 99Si e-brake cables fit EG?
Like the title says. I have a 95 CX, and I got a 95 Integra rear disc conversion, and it didn't come with e-brake cables.
I was wondering if the cables from a 99 Civic Si would work, or do I need the Integra ones?
Thanks!
Thanks!
I did a search, and I am getting conflicting information, hence my post. So if someone knows FOR SURE if they will work, please let me know. Much appreciated.
i realize that, but i was wondering if the 99 ones will fit, because i can get those for free from a friend. i'd have to shell out a decent amount of cash to buy new 92-95 ones from honda.
Yes they will fit and work fine as will the ones from the following cars:
94-01 integra
92-95 civic (si or 4dr with rear disc, even some Ex's came with rear disc(rare))
92-95 del sol (w/ rear disc)
Modified by wilsel at 9:42 PM 2/22/2005
94-01 integra
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike K »</TD></TR><TR><TD CLASS="quote">did you also use the 99si trailing arms or did you use integra ones?</TD></TR></TABLE>
Does it really matter. Cause there the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">
there the same.</TD></TR></TABLE>
werd!
werd!
If you have to get e-brake cables separatly, you should be looking for 92-95 Si ones. They will fit perfectly. The drivers side integra cable doesn't directly bolt on, and was a pain in the *** for me to adjust the e-brake lever. I still want to replace it because my e-brake handle goes way up. It seems drivers side is shorter than the passenger side.
You can get them at HondaAutomotiveParts for around $40 each new...
PrimeElement
Oct 15, 2007 03:03 PM
jus_spooln_wicha
May 14, 2007 12:40 AM
dem0nk1d
Mar 16, 2006 11:45 AM
