new bearings((emergency!))
Old Feb 22, 2005 | 09:37 AM
MugenLudenB00st's Avatar
Default new bearings((emergency!))
I have a 97 Prelude and just got my GE sleeves for my h22 block. I got new JE pistons and Eagle H-beam rods so now I need new bearings. My question is this: Do I just need to go to the Honda dealer and ask to get new bearings for my Prelude or are there specific ones that I need to get? The reason I ask is because I was told that the green bearings would work but my friend is boosting his b18 in his hatchback and said that those weren't right. So I decided to come here and ask since Honda-Tech is full of people who are more knowledgable than me. Help is greatly appreciated.
Old Feb 22, 2005 | 10:22 AM
LudeyKrus's Avatar
There should be a place where the stock bearing sizes were stamped. BUT if you're using a different crank, that's useless.
Honda bearings are the only ones that you can choose sizes; aftermarket H22/H23 bearings are one-size-fits-all.
Either:
- measure your crank journals and figure the clearances you need, then buy the correct Honda bearings
- Use the bearings marked on your block if you are using the original crank and it's in good shape and is unworked
- Buy some ACL's, or other aftermarket bearings, toss them in, and plastigage them to make sure you have the clearances within spec.
Old Feb 22, 2005 | 02:27 PM
yeah, my crank is the same one since it is still in good conditions where it doesn't need any work done to it. I called Honda and they told me that a number should be on the rod(e.g. 1) and a letter on the crank(e.g. A). I should get those to them they told me. The only thing is this, when I look at the crank I see 3C, then a B, then 4, followed by a B, and followed by a 3. This is kind of getting to me since this is one of the few times I don't really know much on a subject. Any more advice please!!!
Old Feb 22, 2005 | 04:18 PM
Mykizism's Avatar
service manual is your friend
also i wouldnt bother with the OEM bearing sizing.. get acls' they work great
just besure to check the clearnces and ur good to go
Old Feb 22, 2005 | 04:28 PM
Speedra500's Avatar
Default Re: (Mykizism)
just measure the crank, and measure the journals, or get 1 bearing and use plastiguage and measure all the clearances accordingly and pick the bearing that would be within the spec that you want, I personally would not go with ACL since they are all generic size and your block/crank/rods are not, but thats just me
Old Feb 23, 2005 | 12:25 PM
19924ws's Avatar
Default Re: (Speedra500)
I'll email you the pages you need from the factory service manuel
Mike
anyya8
Jun 25, 2011 07:50 AM
Prudz_lude
Jan 11, 2010 08:14 PM
shandonwall
Mar 27, 2009 10:54 AM
dustin_68f100
13
Jan 30, 2008 06:27 AM
super laubo
Mar 24, 2003 03:15 PM
