Need opinions before building C-pillar brace
Old Feb 22, 2005 | 07:42 AM
kndaqikEG's Avatar
Default Need opinions before building C-pillar brace
I am currently getting ready to build my own C-pillar brace and triangulation brace as well. I need some input on my idea. If I were to use a 1" maybe 1.25" thick wall aluminum tubing, would it be strong/stable enough if I just pretty much stuck a spherical rod end insde the tube, and bracket it all up and use the nuts on the ends to adjust(push) the tube? Or would I be better off to go one size higher on the rod end and just put threads inside the tube itself? Sorry about the grammar
Old Feb 25, 2005 | 08:00 AM
kndaqikEG's Avatar
Default Re: Need opinions before building C-pillar brace (kndaqikEG)
C'mon folks, good bad or indifferent?! I could also weld threaded inserts into the tube as well, but would the strength but that much more significant for the extra work?
wade
Welding / Fabrication
23
Jan 27, 2008 09:32 AM
PasswordEM2
Honda Civic (2001 - 2005)
Nov 4, 2007 08:56 PM
atg1290
Sep 3, 2006 03:55 PM
satan_srv
Jan 3, 2003 10:36 AM
