PIRELLI PZero Nero M&S
I was searching for tires and I was interested in PZero Nero M&S they have a great rating
DRY Traction: 9.1
Wet Traction: 8.8
Hydro Resistance: 8.8
Snow Traction: 7.5
Cornering Stability: 8.8
Steering Response: 8.8
Noise Comfort: 8.8
Tread Wear: 8.7
I was thinking about getting theses or Bridgestone s03's
what do you guys think
http://www.tirerack.com/tires/...M%26S
http://www.tirerack.com/tires/...ition
DRY Traction: 9.1
Wet Traction: 8.8
Snow Traction: 7.5
Noise Comfort: 8.8
Tread Wear: 8.7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IBriaIN »</TD></TR><TR><TD CLASS="quote">I was thinking about getting theses or Bridgestone s03's
what do you guys think</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 »</TD></TR><TR><TD CLASS="quote">M&S = mud and snow, right? That's a very very good winter tire then.</TD></TR></TABLE>
No, the M&S tire is an all-season tire, not a winter tire.
The Bridgestone S-03 is a high-performance tire, often called a "summer tire".
All-season tires are designed as a compromise for people who want to use the same tire during warm weather as they do on snow and in frigid temperatures. In warm weather, they're worse than most summer tires (on dry AND wet pavement), but better than winter tires. On snow, they're not as good as winter tires, but better than summer tires.
Since you live in the O.C. with Ryan, Seth, Marisa, Summer, and Zack, you don't have to worry about snow or cold, so you shouldn't be getting an all-season tire. That makes the choice easy between these two tires; get the S-03. The S-03 is an excellent tire, with great traction on dry pavement as well as in rain. A bit pricey, tnough.
In addition to the S-03, there are some other tires out there that are also excellent, depending on your needs, including the stock Bridgestone Potenza RE010, the Falken Azenis RT-215, the Yokohama AVS ES100, and the Kumho MX. For more details and recommendations, click here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">Since you live in the O.C. with Ryan, Seth, Marisa, Summer, and Zack, you don't have to worry about snow or cold,</TD></TR></TABLE>
rofl -- you crack me up nsxtasy...
I had PZero Asymmetricos. They rocked, super precise feel, great adhesion. Treadwear was OK, I cracked a rim before they were totally gone, and tossed them. I'm strongly considering going back to PZero because of the 16" tire availability.
-Chris
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">I had PZero Asymmetricos. They rocked, super precise feel, great adhesion. Treadwear was OK, I cracked a rim before they were totally gone, and tossed them. I'm strongly considering going back to PZero because of the 16" tire availability.</TD></TR></TABLE>
Just keep in mind that Pirelli makes a lot of different tires with similar-sounding names. Right now the Tire Rack shows the following different models with the PZero designation:
<u>Max Performance Summer</u>
PZero Nero
PZero Rosso Asimmetrico
PZero Rosso Direzionale
PZero System Asimmetrico
PZero System Direzionale
<u>Ultra High Performance All-Season</u>
PZero Nero M&S
<u>Competition</u>
PZero Corsa
PZero Nero
PZero Nero M&S
<u>Competition</u>
PZero Corsa
gocivicgo
May 24, 2003 08:53 AM
