h22 ECu
Old Feb 21, 2005 | 10:44 PM
hqr180's Avatar
Default h22 ECu
I was told a few days ago that u can use the p28 ecu with h22spec rom for an h22a swap into an ej....?????
Anybody know if this is true?
Old Feb 21, 2005 | 10:49 PM
h22John's Avatar
Default Re: h22 ECu (hqr180)
whats p28? GSR? if so then yes you can use a p28. typically gives higher top end but lose some midrange, from graphs ive seen............John
Old Feb 21, 2005 | 10:54 PM
showtymers619's Avatar
* B A N N E D *
Default Re: h22 ECu (h22John)
p28 is singlecamvtec
p72 is gsr
yes you can use a p28 chipped but you won thave knock or IAB
with the gsr you can still use both ofthose or disable it
p28 it automatically disabled
Old Feb 22, 2005 | 04:09 AM
94_HATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hqr180 &raquo;</TD></TR><TR><TD CLASS="quote">I was told a few days ago that u can use the p28 ecu with h22spec rom for an h22a swap into an ej....?????
Anybody know if this is true? </TD></TR></TABLE>
YES...this is true. I have this done on my h22 eg hatch. You can get an h22 program to run off a p28...that does disable you knock sensor and secondaries for your butterflies inside the intake manfold. If you running a single runner intake manifold that wont matter(obviously). If not just take out the secondaries and your set.
Btw....I along with a few others have used newmans h22 program with p28 with good results. But, there are others and i suggest you search before buying one.
Chris
Old Feb 24, 2005 | 06:21 AM
hqr180's Avatar
Default Re: h22 ECu (94_HATCH)
so i could also use the type R ecu also right?
jays01
Engine Management and Tuning
Feb 6, 2009 07:35 AM
discrete
Nov 18, 2005 08:25 PM
xd69
Apr 27, 2005 02:34 PM
O RLY
Oct 5, 2004 10:42 PM
abeaujuin
Jul 27, 2004 09:01 AM
