b16a2 nitrous question
i have a b16a2 in my eg hatch and going to have a zex wet kit installed ...i was wondering what will i need to upgrade to be safe...fuel system?? the shop that is going to install it for me said with stock internal 55 shot is safe ...i want to make sure before i install it cause they might say that just to make money...and i was wonder what will i run in a 1/4 mile? with a b16a2 i/h/e wiht 55 shot nitrous...thanks..anything will help
I would say upgrade your fuel pump (i.e. Walbro 255 or something equivalent), im running the ZEX dry and that was definitely the first upgrade I did, also make sure you are running colder spark plugs than stock, and make sure your timing is correct according to how much you plan on squeezin!
As for times I would say low 14's....possibly high 13's if you run slicks! Good luck!
