pulley problems
Old Feb 21, 2005 | 07:18 PM
01 EBP TYPE SH's Avatar
Default pulley problems
i have aem power pulleys for ps and alt and i also have unorthodox crank pulley installed on my 2001 type SH with other mods, the belts are starting to slip ( i can here them slipping, ecp. when i turn on the air conditioner or heater) just wandering how do i tigfhten them or fix the problem and wat tools do i need?
Old Feb 21, 2005 | 07:41 PM
vinuneuro's Avatar
Default Re: pulley problems (01 EBP TYPE SH)
i would first take off ur aftermarket crank pulley, put ur stock crank pulleyback on and then fix the slipping while ur at it. The stock harmonic dampner on the stock pulley keeps the vibreations down on the crank. People have noticed increased bearing wear the aftermarket crank pulleys.
Old Feb 21, 2005 | 08:23 PM
prelude1897's Avatar
Default Re: pulley problems (vinuneuro)
Exactly do what he said
Old Feb 21, 2005 | 09:28 PM
Speedra500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote"> i would first take off ur aftermarket crank pulley, put ur stock crank pulleyback on and then fix the slipping while ur at it. The stock harmonic dampner on the stock pulley keeps the vibreations down on the crank. People have noticed increased bearing wear the aftermarket crank pulleys.</TD></TR></TABLE>
this is still debatable especially on balanced engines, although I would not put an aftermarket crank pulley on my car, it really hasnt been proven. Although the crank pulley does serve as a harmonic and torsional dampner(I'd rather make power elsewhere)
Old Feb 21, 2005 | 09:29 PM
wat can i do w/o taking off my aftermarket pulleys?
Old Feb 22, 2005 | 05:52 AM
kulrevon's Avatar
get new shorter belts and adjust them. this answer seems so simple.
Old Feb 22, 2005 | 08:11 AM
accord-lude's Avatar
Default Re: pulley problems (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">get new shorter belts and adjust them. this answer seems so simple.</TD></TR></TABLE>
im with him on that... tighten up the belts and see what happen while your at it.
Old Feb 22, 2005 | 10:59 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01 EBP TYPE SH &raquo;</TD></TR><TR><TD CLASS="quote">wat can i do w/o taking off my aftermarket pulleys?</TD></TR></TABLE>
Just tighten the belts. It's not that hard....
Old Feb 22, 2005 | 10:14 PM
PrettyLude's Avatar
tighten the belts, its that alternator pulley you need to take off, i had one, it would idle so low that it would start draining my battery, keep in mind i don't have alot of stereo or electronic equipment
Old Feb 23, 2005 | 09:47 PM
Default Re: pulley problems (Hawkze_2.3)
thanks 4 the advice
Old Feb 24, 2005 | 02:58 AM
SiRLudeVtec's Avatar
This probably has nothing to do with your problem....but just for advice, if you want a sound system in your car, don't change the alt pulley. I don't know if you have a stree or show car.....:D
ebrakeracin4
Jan 30, 2005 09:09 AM
airwalk07143
Sep 24, 2004 07:40 AM
crx00
Sep 28, 2003 11:02 AM
3700 Vtec
Jan 21, 2003 05:55 PM
