How do you know when your fuel pressure gauge breaks?
Old Feb 20, 2005 | 11:19 PM
spidermancivic's Avatar
Default How do you know when your fuel pressure gauge breaks?
my fuel pressure gauge sits at 70 psi at idle, static, and when the car shuts off. there is no change in the way the car runs. it only goes down when you relieve fuel pressure. is this a broken gauge? how do you know if your gauge is broken?
Old Feb 21, 2005 | 07:48 AM
platinum00's Avatar
Default Re: How do you know when your fuel pressure gauge breaks? (spidermancivic)
do you have a FPR,
if so turn it up and down and see if the gauge moves with the increase or decrease in pressure.
platinum.
Old Feb 21, 2005 | 08:42 AM
IN VTEC's Avatar
Take off the vacuum-reference line. The fuel pressure gauge should respond immediately and show an increase of roughly 5psi or so.
Old Feb 21, 2005 | 08:45 AM
DaX's Avatar
DaX
Loved
Community Favorite
The needle on my B&M wrapped completely around and was sitting on the OTHER side of the peg at zero psi...it would not move. I upgraded to a Marshall fuel pressure gauge with silicone inside...this greatly prolongs the life of the gauge, especially one that's mounted in a high shock location like directly on the engine.
Old Feb 21, 2005 | 09:04 AM
PM-Performance's Avatar
Default Re: (DaX)
if its a B&M , its prob broke.
I have broken too many of them things.
Old Feb 21, 2005 | 12:06 PM
pulled off vac from FPR. Still stuck at 70 psi. relieved fuel pressure and it sometimes stays stuck between 70 and 40 psi. tapped it a few times to get it to zero. i think it is jacked up. i might go pick up camp1320's gauge.
Old Feb 21, 2005 | 12:08 PM
platinum00's Avatar
yea it sounds messed up.
i would just pick a new one up
good luck
platinum.
Old Feb 22, 2005 | 10:35 PM
deeweewoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spidermancivic &raquo;</TD></TR><TR><TD CLASS="quote">pulled off vac from FPR. Still stuck at 70 psi. relieved fuel pressure and it sometimes stays stuck between 70 and 40 psi. tapped it a few times to get it to zero. i think it is jacked up. i might go pick up camp1320's gauge.</TD></TR></TABLE>
Sounds broke buy a Marshall like Dax said its the best. check out my sig.
Old Feb 22, 2005 | 11:44 PM
Sonny's Avatar
It sounds like your FMU is stuck. Try adjusting it via the set screw on top. Mine stuck on me a few times.
JR FMU = POS
Sonny
Old Feb 23, 2005 | 09:48 AM
Default Re: (Sonny)
actually, im not on the fmu anymore. im on hondata. i have more problems than just the FP gauge being jacked up. I hope this solves the Fuel pressure problem.
https://honda-tech.com/zerothread?id=1129884
shadykit
Dec 30, 2004 12:29 PM
420aNT
Apr 1, 2003 10:58 AM
irev210
Mar 29, 2003 06:46 PM
