Greddy turbo timer.
Old Feb 20, 2005 | 09:18 PM
zebt66's Avatar
Default Greddy turbo timer.
Like i installed a greddy turbo timer on my friends 99-00 SI......and wired everything right and checked it with a meter.....now soemthign is wrong....cuz i have done apexi ones before.
The turbo timer works liek when u switch it on and turn it off.......but once u start the car up and then shut it off the greddy turbo timer turns off!
Need some help.
Old Feb 20, 2005 | 09:50 PM
torr's Avatar
Default Re: Greddy turbo timer. (zebt66)
the only thing i can think of is that you tapped into the wrong ignition wire
Old Feb 20, 2005 | 09:53 PM
zebt66's Avatar
Default Re: Greddy turbo timer. (torr)
i just saw a wiring diagram...tested it with a testor....everything looks good!
Old Feb 21, 2005 | 06:09 AM
dumpeDc2's Avatar
I'm a Jackass
ya thats so you can leave it off with out it resetting every time you run the car. if you want to cut the timer short just hit it when it is counting down
Old Feb 21, 2005 | 07:24 AM
zebt66's Avatar
Default Re: Greddy turbo timer. (DumpeDc2)
hmm weird.
Old Feb 21, 2005 | 08:21 AM
PrettyLude's Avatar
im willin to bet that its on automode, if you start it up and kill it right away, it will turn off, reason being that it will adjust the timer accordingly based on speed and rpm
ex_on_lsd
Oct 20, 2007 06:20 PM
alfee
Jan 4, 2005 11:02 PM
tegon-gsr
Oct 4, 2004 07:15 AM
thaiphob
Jan 22, 2004 09:15 AM
Ray
Jul 2, 2001 04:01 AM
