coolant temp dash indicator always reads cold when driving
Old Feb 20, 2005 | 07:19 PM
Nextelbuddy's Avatar
Default coolant temp dash indicator always reads cold when driving
i bought a 94 gsr.. the cluster was busted the speedo didnt work and the coolant temp indicator always read cold.. i replaced the cluster with a known working one. speedo works fine but the temp indicator still reads cold. if you let teh car idle in one place for a whle it will get up to proper temp which is almopst near the middle half way point but as soon as you start driving especially in colder air it starts to go down again. i dont get it, i cant figure it out.. anyone ever seen this before
Old Feb 20, 2005 | 07:41 PM
stumpyf4's Avatar
Default Re: coolant temp dash indicator always reads cold when driving (Nextelbuddy)
Thermostat is stuck in the open position. Change it and you're good to go.
Old Feb 20, 2005 | 08:37 PM
Default Re: coolant temp dash indicator always reads cold when driving (stumpyf4)
so thermostat stuck in the open position will cause the car to run cold like that?
Old Feb 20, 2005 | 08:40 PM
virusiidx's Avatar
yeah my car is like that right now, as long as it's not always hot, then its ok to drive around until you replace your tstat. colder is better than hotter.
tstat is cheap anyways, just make sure to buy a new gasket also.
Old Feb 20, 2005 | 09:04 PM
Default Re: (virusiidx)
thanx guys
Old Feb 21, 2005 | 08:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">Thermostat is stuck in the open position. Change it and you're good to go.</TD></TR></TABLE>
one thing about this i dont understand is if the thermostat was stuck in the open position wouldnt the car eventually wamr up to full operating temp?? i mean if i drive the car for over an hour it still reads cold until i come to a stop and idle for a few min.. does this still sound like a thermostat stuck in the open position?
Old Feb 21, 2005 | 08:43 PM
virusiidx's Avatar
if the thermostat is stuck open, it releases more coolant to flow through, making the motor cooler, when it closes, the motors temp is raising because nothing is flowing.
sickofitall1113
Feb 12, 2011 08:11 AM
drmix
Dec 16, 2008 01:01 PM
s1ngle
Dec 12, 2005 05:26 AM
a1320addict
Nov 24, 2005 02:49 PM
donesixer
Jul 13, 2004 08:39 PM
