Buying used valves? yes or no?
Old Feb 20, 2005 | 07:00 PM
DefiantGSR's Avatar
Default Buying used valves? yes or no?
Would you fellas buy used OEM valves? None are bent. What else should I look for? Thanks guys.
Old Feb 20, 2005 | 07:04 PM
jisu009's Avatar
Default Re: Buying used valves? yes or no? (DefiantGSR)
Sure, the valves are rarely out of spec...it is the guides that go bad. Just keep in mind that a new set of valves is only around $200.
Old Feb 20, 2005 | 07:06 PM
DefiantGSR's Avatar
Default Re: Buying used valves? yes or no? (jisu009)
used valves can go for 50 bones!
Thanks for your input, man.
junkyard racer
Sep 7, 2008 04:41 PM
Project X
Jul 5, 2001 08:47 PM
