Need help with dyno video compression
Old Jan 18, 2002 | 08:14 PM
Rboosted717's Avatar
Default Need help with dyno video compression
Compression for my dyno video I'm trying to upload. Its 1min30sec and its 34megs!!!!
I want to post it however I want to compress it before I post it to help those with normal connections. The reason I'm posting it here is because its you guys who will be viewing the video, so you guys know which compression program I should use.
So where do I download load it and will it compress it enough without killing the quality?
Old Jan 18, 2002 | 08:47 PM
GarageQueen213's Avatar
New User
Default Re: Need help with dyno video compression (Rboosted717)
You would want to encode them in the DivX format..
Here are a few sites to get you started..
http://www.divxvid.net/divx.htm http://www.divx-digest.com/software/index.html http://dvd.da.ru/
Old Jan 18, 2002 | 08:49 PM
thanks. I just remebered that I used that last time a few yrs ago. However I found a setting on my Dazzle program thing that allows me to adjust the quality, etc...
I got it to 10megs and I'm uploading to my friends server now. His server is messed up still but it will work for the time.
I'll post a new thread on the video when its done.
Old Jan 19, 2002 | 09:23 AM
Sa-Da-Teh's Avatar
New User
If not to late, I use the dazzle 80 for capturing into avi format. The size is huge, a few hundred megs for a minute's worth. Then I use a compression called avi2vcd, this cuts it way down to about 20 megs and the quality is not worse. I found it on google.
98vtec
Aug 9, 2006 04:12 PM
LSVTEC 91 Civic
18
Nov 10, 2005 06:59 PM
2.2SICKLUDE
Jul 5, 2005 11:37 AM
YellowR2000
Mar 18, 2002 06:22 PM
HX_Guy
Nov 16, 2001 09:33 AM
