Gen5 JDM clear corners
tried to install the JDM clear corners on the gen5 accord but for some reason the upper tab wont reach the top screw. since im replacing my stock corners and i have stock headlights on i know its not an alignment issue for the latter
will the JDM corners fit our USDM headlights?
you need to make modifications to make it fit..ur suuposed to cut away at the upper tab to make it fit
not sure the exact measurements...im sure someones knows
eh? all corner lights should be shaped the same. sounds like you just bought a really crappy set.
I had some "jdm" clear corners, I just pulled mine out and slapped the new ones in.
I'm replacing them with amber ones though because I don't like them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kniob »</TD></TR><TR><TD CLASS="quote">eh? all corner lights should be shaped the same. sounds like you just bought a really crappy set.
I'm replacing them with amber ones though because I don't like them.</TD></TR></TABLE>
i dont think its crappy if theyre made by stanley. its the real deal JDM corners bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii »</TD></TR><TR><TD CLASS="quote">you need to make modifications to make it fit..ur suuposed to cut away at the upper tab to make it fit
i knew it. damn it! i shouldve gotten the headlights as well to match. i figured the JDM headlights would be the same as the USDM as far as fitment is concerned. oh well ill figure it out. just installed by sidemarkers. damn took me 3 hours
</TD></TR></TABLE>i knew it. damn it! i shouldve gotten the headlights as well to match. i figured the JDM headlights would be the same as the USDM as far as fitment is concerned. oh well ill figure it out. just installed by sidemarkers. damn took me 3 hours
hey, suggested by tx tuner and Bone stock i bought these on procarparts.com
i bought them because i recently did a DIY job on my 5th gen headlights
do you think the corner lenses i got will need modificatinos too?? what do you mean by "scraping off the tab"? thanks
thats the same corners i got except mine are the stock chrome (not blacked out).
the upper tabs will not line up to the hole where you will screw it in place
you will know what im talking about when you get your corners and try to install them
i havent seen what the back side of the real deal JDM stanely corners look like but I know the depo jdm black housing corners fit only on depo black housing head lights and to make them fit on OEM lights you got to cut the bracket some so I suppose its the same deal with those stanleys.
i got the jdm amber corners a while ago. i installed one side like nothing but the second side i had the same problem, but then i jus told my friend to push it really hard so the holes will match up and i screwed it on. lol thats not the proper way but it worked
i dont think so i got some depo ones and you still need to make some modifications...the fit onto depo with no problem...well that was how my situation was till i just got the whole set
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyrojeff »</TD></TR><TR><TD CLASS="quote">I remember putting those on a while back. Had to cut off part of the headlight assembly (the black plastic stuff). Wasn't happy doing it, but the look of the outcome made it well worth it.</TD></TR></TABLE>
thats right. had to trim the black portion of the headlight housing (the one immediately behind the corners). the driver side fit into the stock screw hole with little push. the passenger side i had to make a new screw hole
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner »</TD></TR><TR><TD CLASS="quote">The aftermarket corners (not true JDM) fit perfectly because they are modeled after the USDM corners
maybe the ricer APC blacked out euro clear corners but not Depos
</TD></TR></TABLE>maybe the ricer APC blacked out euro clear corners but not Depos
i got my UPS tracking number today, ill be getting my corner lenses tuesday afternoon and then i promise ill snap some shots wen i put them on to see wut theyll look like. see ya
