auto to manual.. searched... sensors on clutch pedal
Old Feb 20, 2005 | 03:11 PM
getnasty's Avatar
Default auto to manual.. searched... sensors on clutch pedal
alright I have a 96 civic auto. and I just put in 97 integra pedals. all is fine except there are two sensors(plugs) on teh clutch pedal.. and I dont see them anywhere under my dash.. do i really need them? Also about wiring the (two fat) wires. I just cut the harness and wire them together? the harness that used to hook to the auto shifter. please help
Old Feb 20, 2005 | 07:08 PM
getnasty's Avatar
Default Re: auto to manual.. searched... sensors on clutch pedal (bottle fed)
HELP!!!!!!!!!!!!!!!!!
Old Feb 21, 2005 | 03:55 PM
ALL IMPORT's Avatar
pmed!!
Old Feb 21, 2005 | 04:06 PM
getnasty's Avatar
Default Re: auto to manual.. searched... sensors on clutch pedal (ALL IMPORT)
replyed thanks.. I cant get it to start!!! somebody help
Old Feb 22, 2005 | 08:22 AM
getnasty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottle fed &raquo;</TD></TR><TR><TD CLASS="quote">HELP!!!!!!!!!!!!!!!!!</TD></TR></TABLE>
Old Feb 22, 2005 | 03:03 PM
Beatkidd's Avatar
one is for cruise control the other is for the start i believe
Old Feb 22, 2005 | 03:14 PM
Rtype16's Avatar
Default Re: auto to manual.. searched... sensors on clutch pedal (Beatkidd)
Okay the wires on the pedal don't worry about they won't be needed since your car was an automatic to begin with. The one wire you do have to ground out is on the wire harness for the automatic shifter. The car will not start unless it is in park. Find this wire and ground it. Or if you really want to get fancy you can take that wire and run it to the pedal. Than the other side to ground so you can only start the car if the clutch is in just like a manual trans.
Old Feb 22, 2005 | 04:10 PM
getnasty's Avatar
Default Re: auto to manual.. searched... sensors on clutch pedal (Rtype16)
thanks guys I got it... I missed the tranny ground
pr0jektdc2
May 9, 2006 07:18 PM
Racewerkz
Oct 16, 2005 07:51 PM
getnasty
29
Feb 23, 2005 07:09 AM
SiViK-R
Dec 25, 2001 08:57 PM
