ZC Not Running
Old Feb 20, 2005 | 02:26 PM
luckeydog14's Avatar
Default ZC Not Running
I had to adjust my cam gears because the exhaust cam was off one tooth from the intake cam so I took off the timing belt and advance the intake cam so that they matched. I put the timing belt back on and now the car wont start. Its getting fuel because I can hear the fuel pump kick on when I turn the key. All it does it turns over and over and doesnt fire.
Old Feb 20, 2005 | 02:51 PM
kulangot's Avatar
Default Re: ZC Not Running (luckeydog14)
i don't think you timed it right....try re-timing it...
Old Feb 20, 2005 | 05:06 PM
SwissChEz82's Avatar
Default Re: ZC Not Running (sirq2u)
check your injectors
Old Feb 20, 2005 | 06:42 PM
crexhf17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirq2u &raquo;</TD></TR><TR><TD CLASS="quote">i don't think you timed it right....try re-timing it... </TD></TR></TABLE> deff try that if not even tho ur fuel pump clicked it still may not be pumpin rite it happened to mine awhile back.
Old Feb 20, 2005 | 07:16 PM
jlong17crx's Avatar
hey...if the exhaust was off do not adj the intake, put the motor back at tdc and match both intake/exhaust to eachother at top dead center!
crazyguy
Jan 30, 2008 07:52 AM
B18C-Hatch
Sep 6, 2006 10:06 AM
integlstrike1
Aug 22, 2006 07:24 PM
rbanke
May 13, 2006 01:17 PM
rspectuning85
Aug 28, 2004 06:44 PM
