Dragging the K24 EG...
Old Feb 20, 2005 | 01:44 PM
fastbrakes's Avatar
Default Dragging the K24 EG...
Finally got to the track with the EG after driving it around for the past 4 months. I've put about 4K miles on it or so and love every mile.
Anyway, made 9 runs on a Friday night in about 2 hours. Best was a 14.9, hopping the wheels until I shifted to 2nd. Didn't have much better luck keeping the tires hooked up all night. Too much RPM's at launch I guess. I havn't raced a car at the drags in about 10 years so getting the touch to just haze the tires at launch was not there. Speed was the same no matter what the time was..93 mph.
Shifted at 7100, just into 4th at the traps...
I did notice it slowing down after a few runs, and then they stopped the action to clean the track, so I thought I'd head home...
I'm making a closed air box to keep the hot air away from the intake so maybe that will help somewhat. I also will be putting taller tires on it to help (has 22.7" tall ones on there now) with the launch. Need to make a bit less torque off the line to keep from hopping...I will also be putting on the Full Race crossmember/strut rod pieces to see if that helps.
Old Feb 20, 2005 | 10:06 PM
Goatsterrman's Avatar
Default Re: Dragging the K24 EG... (fastbrakes)
what kind of 60ft times were you getting?
Anything done to the motor?
Old Feb 20, 2005 | 11:14 PM
racerus's Avatar
Default Re: Dragging the K24 EG... (Goatsterrman)
Which k24 do you have.Is the motor stock.If you don't mind me asking how much did the complete swap cost you.
Modified by racerus at 8:30 AM 2/21/2005
Old Feb 21, 2005 | 08:45 AM
Honda Bull's Avatar
Default Re: Dragging the K24 EG... (racerus)
Not sure on the exact power of a K24 but you probably outta be trapping a higher mile per hour than that. Plus get the launching down too. Good luck.
Most importantly... have fun.
Old Feb 21, 2005 | 09:25 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Can't wait to see what times you end up getting after a few more tries.
BTW, if you still have pics of your shifter setup, you can email them to me and I will post them for you. Send pics to: rotaryfreak3@yahoo.com
Old Feb 21, 2005 | 10:08 PM
racerus's Avatar
bump.pics please.
Old Feb 23, 2005 | 05:17 AM
Jon V's Avatar
Default Re: (racerus)
Specs on the setup?
Old Feb 23, 2005 | 12:02 PM
RangerDan's Avatar
Default Re: (Jon V)
Tires and weight?
Old Feb 23, 2005 | 02:27 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (RangerDan)
What the hell is the k24 from? I hope its not supposedly better than the k20 cause those times kinda blow.
Old Feb 23, 2005 | 02:35 PM
hybrid racing's Avatar
Do you have a volt meter installed in the car?
Is the engine properly ground?
Old Feb 23, 2005 | 04:28 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">What the hell is the k24 from? I hope its not supposedly better than the k20 cause those times kinda blow.</TD></TR></TABLE>
Its out of the CRV. It is rated from the factory at 160 flywheel hp. The motor is also in the Element and Accord, but there are slight differences from the CRV motor.
Old Feb 23, 2005 | 06:26 PM
nickzed20's Avatar
Default Re: (rochesterricer)
what kind of tires? with all that torque, an unexperienced driver, and shitty rubber the times dont suprize me that much
let us know some details: setup, 60ft, tires, launch RPM, etc.
Old Feb 23, 2005 | 06:36 PM
SkankyEJ7's Avatar
its also in the tsx and 4cyl accord right.
Old Feb 23, 2005 | 07:46 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (hondakid1)
Well the Accord was one of the cars I mentioned, and the K24a2 in the TSX has some very significant differences from the one used in this car.
Old Feb 23, 2005 | 08:56 PM
Mike K's Avatar
if it's the crv k24, then those times sound about right... but then again, at the same time, i've seen STOCK b16 swap do mid to low 14s @95-96 mph. the 93mph trap speed seems about right.
time for a k20a2 head, brian!
Old Feb 25, 2005 | 10:43 AM
Nikos's Avatar
Default Re: (Mike K)
He has the accord k24a with k pro. made around 160whp/160tq. Everything is stock. Even has A/C.
Cams are almost out for the k24a... Hoping to bring these motors up to 190 with tuning and even 200 with a better manifold.
That motor doesn';t have the type s/type r/tsx style head. The cams do not have the extra lobe.
Old Feb 25, 2005 | 11:16 PM
Mike K's Avatar
Default Re: (Nikos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos &raquo;</TD></TR><TR><TD CLASS="quote">
That motor doesn';t have the type s/type r/tsx style head. The cams do not have the extra lobe.</TD></TR></TABLE>
yea, i know.. that's why i said to get an rsx-s head. lol.
k24 top end =
Old Feb 27, 2005 | 08:10 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
come on mang, stop lagging and send me those rotors specs. ok. ttyl.
CRAZY-EG9
Oct 2, 2009 11:18 AM
H.A.R.T B18C1EG6
Jun 14, 2005 08:32 PM
daver
24
Oct 21, 2003 11:19 PM
Soled Out
Apr 23, 2003 09:03 PM
