Can you turn a honda/acura crank?
Old Feb 20, 2005 | 10:29 AM
ebrakeracin4's Avatar
Default Can you turn a honda/acura crank?
I have heard its not good to turn a honda crank. I unfortunatly have 2 cranks that have had a rod bearing spin in them. One isnt that bad and the other isnt much worse. I just really dont wanna buy 2 more cranks. Any help would be appreciated.
Old Feb 20, 2005 | 01:40 PM
ekb16's Avatar
take it to a machine shop and have them mircro polish it, my friend did the same wit his gsr crank.
Old Feb 20, 2005 | 09:13 PM
krazie1's Avatar
BANNED
Default Re: (ekb16)
I have always doen that on all my blocks and friends
what would be the problem if they been broken in
I see nothing worng in that
and well if u got them spun bearing there get it to a machine shop there nothing else u can do it has to be worked on
Old Feb 21, 2005 | 09:05 AM
NJIN BUILDR's Avatar
Default Re: Can you turn a honda/acura crank? (ebrakeracin4)
Honda cranks are nitrided from the factory.Its a surface hardening process that gets mostly ground away when you regrind the crank.For the cost of the regrind, and nitriding you could buy a good used std crank for less.
Glenn
Old Feb 21, 2005 | 02:44 PM
drdisco69's Avatar
Default Re: Can you turn a honda/acura crank? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Honda cranks are nitrided from the factory</TD></TR></TABLE>
Is that all honda cranks or just the Type R cranks?
I had a crank with a spun rod bearing. The machine shop said they haven't had much luck with turned cranks holding bearings. They also said what you mentioned about grinding off the nitride surface and having to get it re-nitrided for a great cost.
I brought them a couple different cranks and in the end all they were happy with was a crank out of a known good motor.
Old Feb 21, 2005 | 03:34 PM
Default Re: Can you turn a honda/acura crank? (drdisco69)
All the "b" stuff is,not sure about the rest.
Glenn
mike93eh2
Dec 29, 2010 03:54 PM
DarKStaR5
Nov 8, 2007 07:06 PM
DefinitlyMaybe
Aug 31, 2005 03:20 PM
1700anddroping
Apr 26, 2005 04:03 AM
hatchy
Mar 31, 2002 04:57 PM
