my DIY wideband lambda - what values should I get?
Old Feb 20, 2005 | 02:59 AM
petrv's Avatar
Default my DIY wideband lambda - what values should I get?
I have built my DIY wideband lambda sensor and now I need to check if it runs accurate enough. What values of AFR (or lambda) should I expect on stock Hondas:
1) at idle
2) when cruising with little throttle, constant speed
3) at full throttle?
Second question, where should be the sensor located? So far, I have put the sensor into my muffler tip and at idle, the sensor showed lambda 0.99 - 1.00 (AFR 14.7). Is this OK for idle?
Old Feb 22, 2005 | 08:19 AM
civic-4-ges's Avatar
Default Re: my DIY wideband lambda - what values should I get? (petrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petrv &raquo;</TD></TR><TR><TD CLASS="quote">I have built my DIY wideband lambda sensor and now I need to check if it runs accurate enough. What values of AFR (or lambda) should I expect on stock Hondas:
1) at idle
Second question, where should be the sensor located? So far, I have put the sensor into my muffler tip and at idle, the sensor showed lambda 0.99 - 1.00 (AFR 14.7). Is this OK for idle?</TD></TR></TABLE>
PGMFI.org
and not a good idea to put in your muffler tip. The exhaust at that point has had excess fuel converted and will not provide a true reading
poormans_typer69
Oct 30, 2007 05:10 PM
petrv
Feb 20, 2005 07:44 AM
CA6VTEC
Sep 14, 2004 05:57 PM
prendi
17
Apr 29, 2003 07:38 AM
evo
Apr 29, 2002 06:33 AM
