Which IACV after MPFI conversion?
Old Feb 19, 2005 | 10:34 PM
Shorty3788's Avatar
Default Which IACV after MPFI conversion?
I've finished my MPFI conversion but the idle is eratic. I unplugged the IACV and the idle dropped right down so i think i've found my problem. my question is which IACVs will work? any OBD0? or from what years/models? just want to make sure i get the right part.
Old Feb 20, 2005 | 10:16 AM
Shorty3788's Avatar
Default Re: Which IACV after MPFI conversion? (Shorty3788)
anyone? i just don't want to go through the hassle of getting the wrong parts again.
Old Feb 20, 2005 | 10:57 AM
kaoss_11's Avatar
B A N N E D
what motor
Old Feb 20, 2005 | 12:56 PM
Shorty3788's Avatar
Default Re: (kaoss_11)
it's the stock d15b2 but with the mpfi swap from a d16a6
Old Feb 20, 2005 | 01:30 PM
green91's Avatar
should work fine. im using a d16z6 manifold and iacv and it works great also.
Old Feb 20, 2005 | 07:06 PM
Shorty3788's Avatar
Default Re: (green91)
...i need to know which iacv i need. just as long as it's obd0 or is it specifically for the d16a6 or the d15b2?
Old Feb 21, 2005 | 02:33 PM
green91's Avatar
you use the one for the manifold your using.. IE d16a6 manifold... d16a6 IACV.
Old Feb 21, 2005 | 02:36 PM
crexer's Avatar
when the IACV is unplugged and the idle drops is that good or bad? Also can a IACV be bad even if the computer is not throwing the code for it?
DrewUSARMY
Aug 12, 2011 10:33 AM
AlfieRoach
Apr 10, 2010 12:59 AM
sd_ej1
Oct 14, 2008 06:26 PM
mntuner2
Jun 17, 2006 07:45 AM
green91
Jan 22, 2004 07:27 PM
