plx problem
Old Feb 19, 2005 | 09:40 PM
stockgreencivic's Avatar
Default plx problem
I just installed the plx m-200 wideband and now I get a check engine light. Using it as a standalone, red to power, black to ground, grey to ecu NB input. check engine light is a code 41 (o2) obviously. Can anyone point me in the right direction?
Old Feb 19, 2005 | 10:36 PM
evosol's Avatar
Default Re: plx problem (stockgreencivic)
what do you mean your using the plx as stand alone? do you have the NB o2 sensor in? If you removed your stock o2 then you need a means to disable it. more info would help.
Old Feb 19, 2005 | 10:43 PM
Jim Truett's Avatar
You need to disable the o2 heater circuit.
jjenkins
Mar 6, 2010 08:37 PM
want2rally
Oct 9, 2005 09:37 PM
silverboost
Aug 23, 2005 09:11 AM
allmotorsi04
Nov 24, 2003 07:51 PM
