Would this work?
Old Feb 19, 2005 | 09:39 PM
ServiceAdvisor's Avatar
Default Would this work?
Okay, I've gone through so many diff combo's this week. Here's the story:
Currently, there is a 91 Si flywheel on my DOHCZC. I'm using the 91 SI pressure plate[Exedy or something aftermarket]. I got an 89 DX trans and it wouldn't fit, the output shaft had more splines or less than the clutch disk. So, I swapped the disks from another year. Everything went back together fine, but when I started the car and let the clutch out, nothing grabbed. Didn't even try to move it felt like it was slipping like crazy. 5th and Reverse almost felt like they were going to engage but wouldn't. Could this be that my pressure plate has alot of high/low spots? I have pics, but no way to host them since we-todd is down, anyone who wants to host aim me = HolyHell116. Somebody help me out ! lol, thanks - Darrell
Old Feb 19, 2005 | 09:56 PM
dr_latino999's Avatar
Default Re: Would this work? (DOHCZCCRXSi)
Let's set some Premises first:
1)88 & 89 Clutches had 200mm Disks (Maybe 188, but I don't remember where I heard that number)
2)90 & 91 Clutches had 212mm Disks
3)If a 90/91 PP was used with a 88/89 Disk it would be too large
4)Only 88 had a different spline count.
Now I leave it up to someone else to construct this into a valid argument/explanation.
Old Feb 19, 2005 | 10:11 PM
Okay, well if the clutch disk is supposed to be the exact same circumference as the pressure plate then the clutch disk which I had on there before, the supposed 91 disk is actually smaller than the disk which I am 100% Sure is a 1989 Honda Crx 1.5L clutch disk. So I hope someone can clear this up. Maybe the '91' disk was an 88, I don't know for sure since I got it used somewhat. I just want to know if I can mix a diff clutch disk with a diff pressure plate and it grab, not great but enough to drive. - Darrell
Old Feb 20, 2005 | 03:28 AM
Bump
Old Feb 20, 2005 | 08:55 AM
Bump4Hump
Old Feb 20, 2005 | 08:56 PM
Noone can answer this question? Si flywheel, Pressure plate, throwout bearing, pilot bearing, and DX clutch disk, will it work or no? - Darrell
McGruber
Jan 17, 2011 09:07 AM
Reason01
13
May 1, 2010 09:38 AM
garageEF
Jul 24, 2006 04:40 AM
ServiceAdvisor
25
Mar 9, 2005 09:41 PM
slowman
Aug 9, 2004 10:34 PM
