CEL 4 - (yeah, i searched)
Old Feb 19, 2005 | 07:38 PM
92HB_HB's Avatar
Default CEL 4 - (yeah, i searched)
i accidently set my cams 180 deg out of phase w/ the crank after retorqing my head and wasn't able to get the car started..
when i realized that it was out of phase, i readjusted the cams and now the car starts, runs, and idles fine..
PROBLEM IS: .. Now i've got a CEL 4 and I can't seem get get rid of the CEL.. I even checked the cam timing and its dead on.. I also swapped dizzys w/ my brothers gsr and the code is still present.. This is realy getting to me ..
Does anyone have the Helms manual that has the flow chart to troubleshoot the CEL 4 ?? I saw one on here b4, but it was for obd0, i need one for obd1..
THanks..
Old Feb 19, 2005 | 11:53 PM
jBj's Avatar
jBj
Default Re: CEL 4 - (92HB_HB)
heres some codes
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Evaporative Emission Control System insufficient purge flow
Old Feb 21, 2005 | 03:59 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB &raquo;</TD></TR><TR><TD CLASS="quote">i accidently set my cams 180 deg out of phase w/ the crank...</TD></TR></TABLE>Think about that for a minute...
CalmPalmTree
May 1, 2015 05:03 AM
97civic123
Jul 13, 2007 04:14 PM
invisible
34
Mar 16, 2007 07:19 PM
NAB16AEK
Jan 19, 2004 06:19 PM
97hb
Mar 23, 2002 03:00 PM
