lowered my 87 2day, questions
Old Feb 19, 2005 | 05:03 PM
7mgtemk3's Avatar
Default lowered my 87 2day, questions
okay heres the deal, i put some eibach pro coilovers on the back, which lowered it a bit, gonna adjust them more 2morrow, but i also lowered the front of the car via my torsion adjustment nut. now heres the question, after lowering it, i took it out for a drive, but now it seems REAL shakey when i take off, it also seems a bit loose, did i possibly screw up an adjustment somewhere? or is this normal for torsion suspensions? ill post pics 2morrow
Old Feb 20, 2005 | 06:38 AM
7mgtemk3's Avatar
Default Re: lowered my 87 2day, questions (7mgtemk3)
no takers eh?
Old Feb 20, 2005 | 07:48 AM
87sivtec's Avatar
how low did you go in the front? They don't have a lot of suspension travel to begin with.
Old Feb 20, 2005 | 08:48 AM
xci_ed6's Avatar
Default Re: lowered my 87 2day, questions (87sivtec)
did you get it aligned? did you install longer bolts? did you turn the torsion bar in the tube?
alignment is key, toe changes alot when you lower the front.
Old Feb 20, 2005 | 09:13 AM
7mgtemk3's Avatar
i took the adjudstment bolt all the way down to the last thread, dropped about an inch or so
Old Feb 20, 2005 | 12:17 PM
xci_ed6's Avatar
bad idea, look up how to turn the torsion bars, you've backed the bolt off too far for safety.
also check the condition of your bushings and ball joints. they may be worn out, now they are just working in a different area causing more noise.
northcb7
Suspension & Brakes
Jun 11, 2012 09:36 PM
PIC Performance
Suspension & Brakes
Aug 18, 2005 11:38 AM
JDMB18CEJ1
Suspension & Brakes
Jun 6, 2005 06:06 PM
EJ20
May 27, 2005 12:16 PM
GroundZer0 336
Apr 25, 2003 06:49 PM
