preparing a motor to be swapped...
Old Feb 19, 2005 | 04:57 PM
jadugartir's Avatar
Default preparing a motor to be swapped...
Right now i have a d16z6 block and head. Before i put them together i want to get them both really clean so that they are visually appealing... The block sat for awhile and therefor has a little rust on the mounts and bolts holding the oil pan... so what should i spray on there to loosen up the grime? and what would you use to scrub it to get all that stuff off... i was thinking about spraying the block too once im done. Not some rice color. Im gonna sand and paint my valve cover either black or a dark gray and then go over the raised letters where it says "HONDA" with some fine grit to make it shiny metal. Basically how do you clean up a motor.
Old Feb 19, 2005 | 09:50 PM
jadugartir's Avatar
Default Re: preparing a motor to be swapped... (jadugartir)
how do i get these 2 pieces ready to be put together and swapped? ive never done this before
Old Feb 19, 2005 | 10:13 PM
jadugartir's Avatar
Also, i have an engine stand but im not sure if one size fits all... what size bolts should i use to try and put my block up on it? Sorry if these are n00b questions
Old Feb 20, 2005 | 07:46 AM
bagpipe goatee's Avatar
degreasers like simple green and stuff are good for cleaning
hYbRid_Eg6
Jan 30, 2012 03:00 AM
crip
Jan 25, 2010 07:33 AM
LUXXXX
Aug 16, 2006 08:16 PM
D3U1LT
17
Jul 30, 2005 06:39 PM
int3gra
Mar 2, 2004 10:02 PM
