Catalytic Converter Gaskets
Old Feb 19, 2005 | 04:45 PM
91z28-350's Avatar
Default Catalytic Converter Gaskets
Hello,
I got a code 67 on my 97 Integra GS. I took down the cat to see if there were any holes (there were some breaks in the brick). Anyhow, there were no gaskets on the rear converter flange. That doesn't seem right to me.
So, I went to get some gaskets for the catalytic converter on a 1997 Acura Integra GS, CA smog model if it matters. I was given Felpro 60517 (rear) and 60669 (front donut gasket). Now I can see how 60669 fits, but how does 60517 fit? It's a ring, and from the look of the flange it should be a flat metal gasket with 3 holes for the bolts in a triangle pattern with a hole in the middle for the exhaust. There doesn't seem to be any groove to fit the ring into. All the parts stores keep giving me 60517.
Thanks!
Old Feb 19, 2005 | 05:54 PM
BlackSage's Avatar
Default Re: Catalytic Converter Gaskets (91z28-350)
When I had my 2000 civic si the car was rattling because that same gasket was missing. What I did was I loosened the bottom two bolts and slid the ring in the middle. I tightened the two bolts back and the rattle went away. On my 00 gsr I used the gasket you described with the three holes. Bottom line is I dont think it matters which one you use....
HTH
dod
Jun 30, 2006 09:19 AM
HB1234
Jan 12, 2006 07:48 PM
PINKMONST3R
Jun 15, 2004 11:45 AM
jdmspoonitr
Sep 22, 2002 03:31 PM
BryanS
Sep 17, 2001 08:10 PM
