rotor problems
Old Feb 19, 2005 | 04:20 PM
turbo01LS's Avatar
Default rotor problems
I was changing my rotors and pads today and the tip of my impact driver bit broke off in one of the screws on the rightside rotor and is stuck in there, has any one has this happen? how did you get it out, i wanted some input before i drilled out the head of the screw so i could slip the rotor over it and then get it out. or i was going to try and weld a bolt to it and get it out that way. i don't care about damaging the rotor since it is being replaced anyway. thanks for the help!
Old Feb 19, 2005 | 04:45 PM
Racermech's Avatar
Default Re: rotor problems (turbo01LS)
Just drill it out. . once the rotor is off you can grab the rest of the screw with some pliers and pull it out.
Old Feb 19, 2005 | 08:41 PM
pubestripe's Avatar
Default Re: rotor problems (Racermech)
yep drill her out and u should be set or u can get a screw extractor also
belairbrian
10
Mar 1, 2013 06:14 PM
zirac50
May 3, 2007 05:15 PM
Knight1
Dec 10, 2005 09:35 AM
Flux
Sep 7, 2005 10:58 AM
Draggin99Si
Sep 5, 2003 06:43 PM
