My Lotus project- Operation Bushings!~
Old Feb 19, 2005 | 03:39 PM
Want2race's Avatar
Default My Lotus project- Operation Bushings!~
Stock Miata bushings suck!
Finally coming along SLOWLY! Need to get more done in less time and find more time!
Old Feb 19, 2005 | 05:40 PM
evosol's Avatar
Default Re: My Lotus project- Operation Bushings!~ (Want2race)
looks familiar... my buddy is also building a lotus 7. i'll try to get some pics of it sometime soon. That thing is deffinately gonna be a auto cross monster.
Old Feb 19, 2005 | 06:46 PM
coupequattro's Avatar
Why is there no/not alot of triangulation in your frame? The thing looks like it will lack alot of essential chassis stiffness. A chassis with square or rectangular bracing is inferior to a chassis with proper triangulation that braces the entire car to prevent flex under heavy loads.
Just an observation
Old Feb 19, 2005 | 07:01 PM
Want2race's Avatar
Default Re: My Lotus project- Operation Bushings!~ (coupequattro)
Cause I am not near finished.. I still have about 60 ft of tubing to go into the car,
Basically I built the skeleton and I will add in the Triangles as I get closer to having fitted most things!
Thanks tho!
Old Feb 19, 2005 | 11:02 PM
cool man I would like to see more pictures of the project as it moves farther along. its always nice to see grass roots car building. check out this guy he is going a similar route as you. good luck
http://www.dpcars.net/
Old Feb 20, 2005 | 12:23 AM
117's Avatar
117
What RPM did you set the lathe at, and how much were you taking off on each pass? Is that Delrin? Thanks!
Old Feb 20, 2005 | 04:10 AM
Want2race's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">What RPM did you set the lathe at, and how much were you taking off on each pass? Is that Delrin? Thanks! </TD></TR></TABLE>
Around 250rpm.
Its Acetal which is like Delrin
Took off .75mm per pass..
Old Feb 20, 2005 | 11:50 AM
gpteitz's Avatar
Default Re: (Want2race)
Cool project...
Curious to know a couple things (going to do DIY bushings soon):
What tolerances do you machine to for a press-fit? Just a couple hundredths extra?
Also, is the inner sleeve bushing necessary? Seems to me you'd not need it?? Less friction??
Why acetal & not UHMW instead?
Thx...
Old Feb 20, 2005 | 12:21 PM
xci_ed6's Avatar
Default Re: (gpteitz)
have any good sites about kit cars/replicars? I have always been interested in building one.
Old Feb 20, 2005 | 02:35 PM
Want2race's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gpteitz &raquo;</TD></TR><TR><TD CLASS="quote">Cool project...
Thx...</TD></TR></TABLE>
I machined them to .01mm over the holes size.. So it was pressed in and HELLA tight!
I used the pins just so I get the full benefit of the isolation and so that there is less friction on the surface of the bushing!
Old Feb 20, 2005 | 02:37 PM
Want2race's Avatar
Default Re: (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">have any good sites about kit cars/replicars? I have always been interested in building one.</TD></TR></TABLE>
What car? I have over a couple hundred kit car favorites..
And why Acetal ? Because its like Delrin but more heat resistant.. I wanted Nylon 6/6 but couldnt find it in a 3" log
Old Feb 21, 2005 | 11:53 AM
Archidictus's Avatar
Unceasing Measure
...you made your own bushings from bars of stock? You = a badass in my book
Old Feb 21, 2005 | 03:54 PM
Formula Racing's Avatar
Default Re: (Archidictus)
what are those pins made from ?
Old Feb 21, 2005 | 04:19 PM
xci_ed6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Want2race &raquo;</TD></TR><TR><TD CLASS="quote">What car? I have over a couple hundred kit car favorites..
And why Acetal ? Because its like Delrin but more heat resistant.. I wanted Nylon 6/6 but couldnt find it in a 3" log</TD></TR></TABLE>
no idea, i need a begginer type site. where i can just read about what people are doing/having trouble with, etc... so i can decide when im ready to attempt building my own.
Old Feb 21, 2005 | 05:06 PM
have you looked at kit car.com?
Old Feb 21, 2005 | 07:41 PM
xci_ed6's Avatar
Default Re: (Formula Racing)
trying now
Old Feb 22, 2005 | 03:32 AM
Want2race's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Formula Racing &raquo;</TD></TR><TR><TD CLASS="quote">what are those pins made from ?
Stainless
Old Feb 22, 2005 | 06:27 AM
legendboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Want2race &raquo;</TD></TR><TR><TD CLASS="quote">Stock Miata bushings suck!
your welding could use some work before you decide to built a kit car!
Old Feb 22, 2005 | 08:46 PM
Want2race's Avatar
Default Re: My Lotus project- Operation Bushings!~ (legendboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote">
your welding could use some work before you decide to built a kit car! </TD></TR></TABLE>
Its not a final weld.. Just a first bead, Its strong as hell tho!
Old Feb 24, 2005 | 05:30 AM
Goullish's Avatar
Its not a final weld.. Just a first bead, Its strong as hell tho!</TD></TR></TABLE>
Um, I'm guessing that's relatively thin wall (.065?) square tube there. There isn't any need for a "final weld". Your first run should be your last with that stuff.
Just a question, why the abundant use of square tube? Round tube is stronger, and because of this you can use thinner wall, making it lighter.
Old Feb 24, 2005 | 08:47 AM
xci_ed6's Avatar
Default Re: My Lotus project- Operation Bushings!~ (Goullish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goullish &raquo;</TD></TR><TR><TD CLASS="quote">Just a question, why the abundant use of square tube? Round tube is stronger, and because of this you can use thinner wall, making it lighter.</TD></TR></TABLE>
my guess? square ube is much easier to work with, since you can make any angle joint with just a hacksaw. No need for cutting angles through tube with a hole saw to get a good joint.
Old Feb 24, 2005 | 01:13 PM
Probably if he was going to change anything he wouldnt want to do the best work OR if its a hard to get at area.. but other than that your right.
m R g S r
Other Make Vehicles
56
Aug 10, 2008 06:13 PM
turbotime
Oct 31, 2004 02:46 PM
rodrez.
Apr 6, 2004 04:11 PM
user 996328629
Apr 15, 2003 10:29 AM
Total'd GSR
Oct 28, 2002 10:12 PM
