HONDA ACCORD COILOVER INSTALLATION
Old Feb 19, 2005 | 03:29 PM
romani's Avatar
Default HONDA ACCORD COILOVER INSTALLATION
HI I WANT TO KNOW FRONT 450 WITH 350 IN REAR? SOMEBODY HAVE LINK STEP BY STEP TO INSTALL?
ACCORD 92
Old Feb 19, 2005 | 04:36 PM
adio's Avatar
Default Re: HONDA ACCORD COILOVER INSTALLATION (romani)
at checker or auto zone they have engrish versions of chilton's manuals, you might want to pick one up
Old Feb 19, 2005 | 06:47 PM
TxTuner
Guest
Posts: n/a
Default Re: HONDA ACCORD COILOVER INSTALLATION (adio)
Lift the car
Pull the wheels
Unbolt the struts (front and rear) from the towers
Unbolt them from the control arm
Pull them out
Remove top of strut
Remove spring
Throw on Coilover's
Reverse....
It's not a complicated task
Old Feb 19, 2005 | 06:50 PM
jakeiscool's Avatar
Banned
Default Re: HONDA ACCORD COILOVER INSTALLATION (TxTuner)
You just cant remove the spring like that. You need a compressor obv.
Old Feb 19, 2005 | 06:51 PM
TxTuner
Guest
Posts: n/a
Default Re: HONDA ACCORD COILOVER INSTALLATION (JakeIsCool)
SSSHHHHHHH!!!!! Let him figure that out himself
Old Feb 20, 2005 | 06:11 AM
jakeiscool's Avatar
Banned
Bad comment TXTuner, that is very unsafe to "figure out" itd be a bad suprise.
Old Feb 20, 2005 | 08:11 AM
TxTuner
Guest
Posts: n/a
Old Feb 20, 2005 | 12:39 PM
ProjectDarkBlack's Avatar
i didnt use a spring compressor, i layed the assembly down between two tires and put a towel over the set up while i unbolted it, unless the accords have preloaded springs
Old Feb 20, 2005 | 12:46 PM
philadd's Avatar
Default Re: HONDA ACCORD COILOVER INSTALLATION (ProjectDarkBlack)
They're preloaded. Use a spring compressor. You can borrow the spring compressors from Autozone for a fully-refundable deposit or about $50.
Old Feb 21, 2005 | 09:16 AM
mrxhe1neken's Avatar
when i installed springs for my car i used spring compressors. but then for my friends car we thought it was so time consuming that we just put it between the tires. o and wen i first installed my springs i didnt know that you needed one of those octogonal tools to place into the top of the strut to remove the nut. so if youre having problems removing the nut at the top, its because u need to use that tool.
Old Feb 21, 2005 | 10:02 AM
TxTuner
Guest
Posts: n/a
Default Re: HONDA ACCORD COILOVER INSTALLATION (mrxhe1neken)
That "octogonal tool" is called an Allen key
Old Feb 21, 2005 | 12:23 PM
BigBadBiologist's Avatar
and that "octogonal tool" is really hexagonal
Old Feb 21, 2005 | 06:37 PM
lol i knew it was called an allen key, but wasnt sure if romani knew what it was called.
Old Feb 21, 2005 | 06:48 PM
95accordh22a's Avatar
no need for spring compressor, i have done many coilover installs the whole fun of the day is when you get to use an impact gun to take of the top nut and hold the sttrut with your foot and tell your friends to watch out when the spring goes flyin
navcc
Apr 10, 2011 12:42 AM
German_Accord
Suspension & Brakes
Apr 14, 2009 07:59 PM
tvomalley
Oct 26, 2008 07:58 PM
Ruskimafia
Apr 7, 2006 01:39 PM
fe519
Jul 6, 2003 09:57 PM
