Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
205's on 13x5's
Old Jan 18, 2002 | 02:22 PM
Lo-Buck EF's Avatar
Default 205's on 13x5's
i know this topic has been posted before, but i couldn't find it via search. i'm thinkin of running 205 50 (race tires) on my stock 13x5's and i was wondering if they'd fit? as far as i know, they won't rub but i was wondering if theyd fit on the rim.
Old Jan 18, 2002 | 02:37 PM
jsi's Avatar
jsi
Default Re: 205's on 13x5's (SOLOef)
Well, first i dunno of any race tires available in 205-50-13 size. The closest is the Yoko A032 in 215-50-13. The new Kumho Ecsta V700 is available in that size. Both spec a minimum 6" rim. Even the 205-60-13 sizes require a minimum 5.5" rim. About the only size that can be used with 5" rim according to mfg specs is 175-60-13 size. Now, you'll probably be able to mount a 205-60-13 tire on a 5" rim, but it's far from an ideal scenario. But then if you're on a really tight budget... It may just have to do, hehe... But seriously, think about getting at least a 13x6 rim...
Old Jan 18, 2002 | 03:23 PM
Jan in Omaha's Avatar
I believe Russ Blume ran BFG R1 (not gForce) 205's on 13's in 2000 on his HS Civic S.
Old Jan 18, 2002 | 03:42 PM
.RJ's Avatar
.RJ
Default Re: 205's on 13x5's (Jan in Omaha)
Yep, and i know of some CRX owners that have run 215's on a 13x5 rim. Its less ideal than running it on a 7" rim, however it still works.
-Ryan
Old Jan 18, 2002 | 05:07 PM
Lo-Buck EF's Avatar
Default Re: 205's on 13x5's (Type-RJ)
excelent...thanx guys
Old Jan 19, 2002 | 04:37 AM
GSRMatt's Avatar
25 Year Member
We run BFG and Yoko 205-60-13s on the stock civic steelies (i think they're 5.5" wide, but might be 5"), and they work just fine. They don't pinch nearly as bad as 225-50s on the 15x6 stock integra wheels, which everyone runs.
Old Jan 19, 2002 | 07:51 AM
RacerMike's Avatar
The ES National Champ, Rob Carpenter, ran 225/45-13s on his 85 CRX Si stock rims...I think those are 5" wide. Finding someone to mount them won't be easy tho...
Old Jan 19, 2002 | 09:29 AM
.RJ's Avatar
.RJ
Default Re: 205's on 13x5's (RacerMike)
No, but it can be done. Some tire shops will look at 205's and a 5" rim and say "nope, cant mount 'em......." but an experience tech or a race/specialty shop will do that for you.
-Ryan
Old Jan 20, 2002 | 03:56 PM
Lo-Buck EF's Avatar
cool, thanxs for the info
Old Jan 21, 2002 | 11:09 AM
5gen-hybrid's Avatar
New User
How about a 205/55/14 nt-555r on a stock civic ex 14'' rim?
Does anybody know anything about the falken azenis? They have the look of a sticky tire but i've never heard anything abou them?
Old Jan 21, 2002 | 11:33 AM
Default Re: 205's on 13x5's (5gen-hybrid)
I put Hoosier 205/55 on 14 x 5 rims. It's a squeeze... but it works
Old Jan 21, 2002 | 11:38 AM
Lo-Buck EF's Avatar
the falkins are a nice tire. i ran sts last season and we discussed the tire all year. basically, there like a crappy race tire/excellent street tire. kinda like the yoko advans but with an sts legal tread wear rating. from what i've gatherd from speeking to a bunch of people who were running them, if ur comming from street tires, u'll like them. if ur comming from r's, u'll think there a good street tire, but lack the grip of an r. which makes sence cause there a street tire, not an r-compound.
Old Jan 21, 2002 | 12:51 PM
New User
I've ran the falcon zeiks in the past (205/40/16's) and i really liked the performance on dry pavement but when it came to wet (raining out) i wasn't to happy with the performance.The nitto's i have now suck on dry pavement but are better in the rain then the falcons.I'm just looking for a dot drag tire without going full blown slicks with tubes.Reason being you have to have dot approved tires to run T&T at our local track.So i'm going to give up a little traction for the ability to run t&t and get more practice.
One other question Which set-up do you think would be the best for quarter mile racing
1) stock ex rims with 205/55/14 nitto drag radial or bfg drag radial.
2)a set of 15' konig helium (ultra light race wheel) with 205/45/15 nitto drag radials or 205/50/15 bfg drag radials (i'm not possitive but i think that make the bfg's in that size).Thanks
B_Swapped93
Nov 25, 2013 12:52 PM
poseghatch
May 23, 2013 02:51 PM
accordinglyevil
Nov 19, 2007 06:34 PM
Bbasso
Apr 24, 2003 01:32 AM
gsr camel
Jan 1, 2002 07:50 PM
