idle problem
Old Feb 19, 2005 | 10:57 AM
drewcandraw's Avatar
Default idle problem
well im a teenager driving a 91 crx hf and i have a problem...my idle is mad crazy...after i take it out of gear at a stop sign the idle starts going crazy between the 800-1000 rpm mark....its fluctuates up and down.. sometimes fast sometimes slow....when i step on the clutch and put it in first and let the clutch ease off it goes away....some people told me it was the timing belt but im not sure...can someone help me fix the problem on my own without me going to a mechanic....
also can someone give me basic directions to install a short shifter tooo....thank you
-andrew
Old Feb 19, 2005 | 12:27 PM
Riceburner247's Avatar
Default Re: idle problem (drewcandraw)
Throttle Position Sensor
My hatch bounces between 1000 and 1500 when warming up in the morning.
Old Feb 19, 2005 | 01:40 PM
Default Re: idle problem (riceburner247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">Throttle Position Sensor
My hatch bounces between 1000 and 1500 when warming up in the morning.</TD></TR></TABLE>
where is that throttle position sensor located???what do i do when i find it???
Old Feb 19, 2005 | 02:15 PM
ELAMINT5's Avatar
could also be a vacum leak. Short shifter. Jack up car, up bolt shift linkage and install short shifter. DONE!
Old Feb 19, 2005 | 03:26 PM
88cerx's Avatar
Default Re: idle problem (ELAMINT5)
800-1000 rpm bounce is usually the idle air controll valve on the back of the intake manifold in the middle has 2 12 or 14 mm bolts on it
Old Feb 20, 2005 | 01:28 AM
Default Re: idle problem (88cerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88cerx &raquo;</TD></TR><TR><TD CLASS="quote">800-1000 rpm bounce is usually the idle air controll valve on the back of the intake manifold in the middle has 2 12 or 14 mm bolts on it</TD></TR></TABLE>
so what am i suppose to do..loosen or tighten the bolts???this is good feedback thanks
Old Feb 23, 2005 | 08:44 PM
88cerx's Avatar
tak it off and clean it if that doesnt work replace it
Old Feb 24, 2005 | 09:17 PM
will do thanks for the help
Old Mar 11, 2005 | 07:34 AM
nota-ex's Avatar
What do we clean something like that with? I just started having that problem this morning. 800 to 1500 rpm
Old Mar 11, 2005 | 11:24 AM
88cerx's Avatar
Default Re: idle problem (nota-ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-ex &raquo;</TD></TR><TR><TD CLASS="quote">What do we clean something like that with? I just started having that problem this morning. 800 to 1500 rpm</TD></TR></TABLE>carb and choke cleaner SPRAY VIGOROUSLY
Old Mar 11, 2005 | 12:27 PM
tpr's Avatar
tpr
Before you start pulling stuff off check the "base idle". Warm the car up to normal operating temperature. Disconnect the IACV (Idle Air Control Valve) electrical connection (back of intake). The car should be idling at 700-750 RPM. If not adjust the base idle with the screw that is above and to the rear of the throttle body opening. If it, the base idle has never been set, there will be a wax plug in the recess. just dig it out. Turn the screw clockwise to slow it down or counter clockwise to raise the idle to 700-750 RPM. Reconnect the IACV and it should idle better.
Old Mar 11, 2005 | 07:45 PM
nota-ex's Avatar
Default Re: idle problem (tpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpr &raquo;</TD></TR><TR><TD CLASS="quote">Before you start pulling stuff off check the "base idle". Warm the car up to normal operating temperature. Disconnect the IACV (Idle Air Control Valve) electrical connection (back of intake). The car should be idling at 700-750 RPM. If not adjust the base idle with the screw that is above and to the rear of the throttle body opening. If it, the base idle has never been set, there will be a wax plug in the recess. just dig it out. Turn the screw clockwise to slow it down or counter clockwise to raise the idle to 700-750 RPM. Reconnect the IACV and it should idle better.</TD></TR></TABLE>
You have a picture or diagram as to where the IACV is? I got intake cleaner and sprayed the inside of the TB. Then I wiped out what I could with a cloth. I wasn't sure where the IACV was, though. I was just hoping that I would get it in the process. If you use something like TB cleaner, don't use too much. Took me 2 or 3 minutes to get the car started after I sprayed it.
go2sleep
Jun 15, 2006 08:54 PM
skimb37
Apr 5, 2005 05:58 PM
choutreux
Apr 18, 2004 07:20 AM
madiaz
Sep 10, 2003 01:13 PM
Vp Special K
Apr 4, 2003 09:14 PM
