Water/ice on inside of windshield every moring
i guess i must have a leak somewhere, but i dunno where. but everyday that its cold out there always ice on the inside of my windshield, and any other days theres sometimes water. Im thinking i could reseal it all,but then again i was reading that sometimes it comes from the sunroof. any one have any idea what im talking about/have the same problem
well if it was comming from the sunroof, your seats would be a bit damp.. or you should be able to run your fingers around the inside of the sunroof and see if you feel any moisture. also do the same for your front windshield.
a way to test this is have someone hold a hose over the top of your car while you're washing it and see if you feel/see any water of any kind come in.
also maybe if the humidity is heavy in your area, which is moisture in the air, and the air is in your car... and the coldness of the outside, could be freezing the moisture to the inside of your windows.
not sayin these are all wrong with your car, but could be some possibilitys to check out
rashidg
Dec 18, 2005 09:15 AM
