h22 accord problem!!!!
Old Feb 19, 2005 | 01:36 AM
h22cord's Avatar
Default h22 accord problem!!!!
HELP me out!!
I have an 93 h22a in my 94 accord ex and for some reason when i down shift and let go of the clutch, I hear this sound like something is in the way of the fan while it's spinning or something. It just started happen today and I dont know what's the problem. If this ever happen to anyone and they know how to fix it, then please tell me. Thanks in advance guys.
Old Feb 19, 2005 | 06:07 AM
Turbowa's Avatar
Default Re: h22 accord problem!!!! (h22cord)
What speed are you at when this happens and does it get louder if you down shift higher up in the rpm range?
Old Feb 19, 2005 | 04:46 PM
h22cord's Avatar
Default Re: h22 accord problem!!!! (Turbowa)
I was going like 10-20 mph on like first or second gear. It only does it on first and second, but I never try downshifting at higher rpm range.
Old Feb 19, 2005 | 06:00 PM
h22cord's Avatar
help me please guys
Old Feb 19, 2005 | 09:15 PM
h22cord's Avatar
anyone know?
Old Feb 20, 2005 | 12:59 AM
h22cord's Avatar
bump
Old Feb 20, 2005 | 09:05 AM
95accordh22a's Avatar
you're front motor mount is prolly gone, so the fan is prolly hittin the bracket
Old Feb 20, 2005 | 11:14 AM
h22cord's Avatar
Default Re: h22 accord problem!!!! (95accordh22a)
thanks...but u sure it's the fan? I know for sure my mounts is gone already
Old Feb 20, 2005 | 03:37 PM
h22cord's Avatar
anyone else knows the problem?
Old Feb 20, 2005 | 04:34 PM
daveedd357's Avatar
check your tranny oil. you probably are extremely low
Old Feb 20, 2005 | 07:41 PM
h22cord's Avatar
Default Re: h22 accord problem!!!! (daveedd357)
where would i be able to know where to check the tranny oil?
Old Feb 20, 2005 | 09:17 PM
honda_kid42's Avatar
alll i have to say is.....HMMMMMMMMMM......
Old Feb 20, 2005 | 09:24 PM
h22cord's Avatar
Default Re: h22 accord problem!!!! (honda_kid42)
hmmm is not going to help..hahahaha
Old Feb 21, 2005 | 08:49 AM
the same thing happened to me its the mount
Old Feb 21, 2005 | 09:00 AM
Luisito825's Avatar
maybe your fan is loose.
Old Feb 21, 2005 | 09:44 AM
puma1077's Avatar
take it to a shop
Old Feb 21, 2005 | 09:54 AM
BaddMo2002's Avatar
if it doesn't happen when your car is @ idle then your fan should be fine. Probably your front motor mount.
Old Feb 21, 2005 | 09:55 AM
h22cord's Avatar
Default Re: (BaddMo2002)
oh i c thanks alot guys
Old Feb 21, 2005 | 05:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaddMo2002 &raquo;</TD></TR><TR><TD CLASS="quote">if it doesn't happen when your car is @ idle then your fan should be fine. Probably your front motor mount.</TD></TR></TABLE>
thats what i said no one listens to me lol
Old Feb 21, 2005 | 10:13 PM
h22cord's Avatar
Default Re: (95accordh22a)
ahhaha
Old Feb 22, 2005 | 08:35 PM
BaddMo2002's Avatar
put on an avatar ...it might help..lol
Old Feb 22, 2005 | 09:15 PM
h22cord's Avatar
hahhaha aite aite
Old Feb 22, 2005 | 10:51 PM
Stoich EG2's Avatar
are you talking abuot grinding?
Old Feb 23, 2005 | 12:05 AM
h22cord's Avatar
Default Re: h22 accord problem!!!! (Advan06)
no it's not grinding....it sounds like something is stuck while something is spinning...it only happen when on first, second, and when i reversed. The sound comes from the driver side.
Old Feb 23, 2005 | 04:10 AM
Slamaccord's Avatar
maybe spider gears in the differential , IDK thats what causing the similar noise in my 5th gen
