My fuel pump is going bad what fuel pump should i look into?Im planning on going NOS.
Old Jan 18, 2002 | 12:24 PM
DroppedTegra's Avatar
New User
Default My fuel pump is going bad what fuel pump should i look into?Im planning on going NOS.
I have a 92 Acura Intera LS..I was wondering what fuel pump should i get if i am planning on going NOS..Are LS fuel pumps good enough for 75-100 shot of NOS?At the dealer there charging me $400 for a GSR pump couldn't i get a better fuel pump for that cheaper than that?
If i got a better fuel pump shouldn't i gain alittle HP also?Also what Fuel Pressure Regulator should i get?
Old Jan 18, 2002 | 12:37 PM
GSRwBOOST's Avatar
Default Re: My fuel pump is going bad what fuel pump should i look into?Im planning on going NOS. (DroppedTe
any name brand pump and adjustable fpr w/ nitrous kit (best thing is to set the fp up a little, do a run and check teh plugs.. )
or
get a decent pump and larger injectors.... w/ nitrous
larger injectors would be safer then trying to pump more fuel through stock ones..
Old Jan 18, 2002 | 03:13 PM
93H22A's Avatar
Wallbro makes good pumps
make sure you have some sort of fuel controller though, otherwise you'll hate your gas mileage.
hardrock2401
Jul 6, 2015 03:31 AM
mr devious illusions
Mar 24, 2007 11:19 AM
VspecSiR
May 17, 2004 04:37 AM
85mm LsVTEC
Dec 22, 2003 10:19 AM
