wheel questions...
Old Feb 18, 2005 | 09:49 PM
BS 22's Avatar
Default wheel questions...
Hey guys sorry for the n00b wheel questions but...
I'm looking to buy some 15" Rota Slips for my 95 civic coupe. I'm not sure which bolt pattern to get, 15x6.5 or 15x7?
Also, if i went with 195/55-15 tires, do you think it would rub if I was running H&R Sport Springs?
TIA,
Brandon
Old Feb 18, 2005 | 09:51 PM
SOHC4life 96's Avatar
Default Re: wheel questions... (BS 22)
Bolt patter is the lug spacing. You need 4x100. What you're thinking of is wheel size. 15" (diameter) 6.5/7" wide. I don't know exactly which size you should get. As far as rubbing, what is the drop on the H&R springs?
Old Feb 18, 2005 | 10:02 PM
BS 22's Avatar
Default Re: wheel questions... (SOHC4life 96)
Optionimports.com says H&R Sports are 1.75 in the front and about 1.6 in the rear.
Thanks for the info also
EDIT: So does anybody have any idea on which wheel size would be better, 15x6.5 or 15x7? Also, which tires would be better for me, 195/50-15 or 195/55-15?
Thanks,
Brandon
Modified by BS 22 at 1:15 AM 2/19/2005
Old Feb 18, 2005 | 10:08 PM
ek9800's Avatar
You need 4x100 stated above. That's the bolt pattern. 15x6.5 and 15x7 are the rim size's. I prefer 15x6.5 butr that's just me.
check sig
*edit* Don't go with a 55 serie's tire. They're huge. get a 50 series.
Old Feb 18, 2005 | 10:31 PM
BS 22's Avatar
Thanks for your help guys
I've decided to go with 15x6.5 inch rims and 195/50/15 tires.
Brandon
DR
Oct 24, 2010 03:10 PM
jxhxb
Nov 17, 2009 06:51 AM
Serenity Now!
Apr 19, 2007 05:08 PM
Boostage
Jun 2, 2005 02:47 PM
JAI-DM
Dec 29, 2003 06:59 AM
