ZC+Y8=high compression?
Old Feb 18, 2005 | 09:30 PM
brg2nr's Avatar
Default ZC+Y8=high compression?
Is it true taht the ZC bottom end and the Y8 head will get a compression ratio of about 12:1? Isn't that relatively high? What does a ZC get for stock compression?
I just bought my first ZC... I am more used to the b16's 18's and H22's so the small stuff baffles me.
Thanks in advance for the info.
Old Feb 18, 2005 | 09:50 PM
90LSpimpin's Avatar
Default Re: ZC+Y8=high compression? (brg2nr)
Dohc Zc or Sohc Zc?
If its the Dohc is not possible.
If its the sohc, the CR would be somewhere around 10.3:1.
Old Feb 19, 2005 | 09:28 AM
bambam's Avatar
in the most recent issue of Honda Tuning, they said that the sohc zc block and the sohc vtec head (can't remember if it was the z6 or y8, but prolly the y8) create a 12.1:1 compression....
I was a little baffled by it...but i haven't heard to many complaints about the info honda tuning puts out...they do have a high standard to live up to.
Old Feb 19, 2005 | 10:58 AM
mellon's Avatar
Default Re: ZC+Y8=high compression? (bambam)
The numbers in honda tuning were with dohc zc pistons and a y8 head not just a plain sohc zc block.
Old Feb 19, 2005 | 12:45 PM
shocker's Avatar
ya,the comp will be that high with the dohc pistons in the sohc and the y8 head,pretty nice setup if you ask me...
alextech
May 22, 2017 07:37 AM
tecster9
May 12, 2008 12:34 PM
l1bid0
11
Nov 13, 2006 09:47 PM
junkyardRx
Apr 15, 2004 12:53 PM
teamrushhatch
Aug 31, 2003 06:36 PM
