Anybody using the Brembo OEM ITR rotor?
Old Jan 18, 2002 | 11:32 AM
RATEDR's Avatar
Default Anybody using the Brembo OEM ITR rotor?
Just wanted to know if these are as good as the stock ones. I dont want to invest in them and have them warp in one week ya know.
Thanks
Old Jan 18, 2002 | 11:44 AM
Chris's Avatar
Default Re: Anybody using the Brembo OEM ITR rotor? (RATEDR)
I use them as my track rotors...they are BETTER than stock!
I reccommend them! Besides that, they are CHEAPER than stock!
Old Jan 18, 2002 | 11:47 AM
Willard's Avatar
I was under the impression that the rotors that are OEM are Honda rotors.
The Brembo OE sized units are a cheaper/better replacement.
Will
-who is p00r and uses Autozone r0t0rs.
[sp]
[Modified by Willard, 3:47 PM 1/18/2002]
Old Jan 18, 2002 | 12:12 PM
typer_801's Avatar
Default Re: Anybody using the Brembo OEM ITR rotor? (Willard)
Brembo's are cheap! <$40 a rotor for an ITR at Colletti Motorsports http://www.collettimotorsports.com. Can't beat that. Can't imagine even Autozone being any cheaper.
Old Jan 18, 2002 | 12:16 PM
Willard's Avatar
Default Re: Anybody using the Brembo OEM ITR rotor? (typer_801)
$29 each baby (95 Legend)
With a 3 month warranty.
Will
-who will have "3" events, using Blues, on the "new" rotors installed on his ITR..
-who will exchange them for new units after the last event
Old Jan 18, 2002 | 12:17 PM
pyromaster's Avatar
what everybody else says about the Brembos
however, does anyone know if they (or anyone) make OEM blanks for the rears?
ITR764's Avatar
will, autozone will be thinking your legend sure does use up some rotors...
Old Jan 18, 2002 | 12:21 PM
Honda318dx's Avatar
Will
Arn't the legend rotors 5mm wider than stock?
typer_801's Avatar
Default Re: Anybody using the Brembo OEM ITR rotor? (pyromaster)
I've heard Accord V6/Acura CL rumors, but have never heard confirmation.
Old Jan 18, 2002 | 12:24 PM
Willard's Avatar
Default Re: Anybody using the Brembo OEM ITR rotor? (Honda318dx)
Not sure... I have been installing "used" pads so... I am not sure if full depth pads would have fittment issues.
I will get the calipers out and compare the Brembos and the Autozone rotors this weekend.
Will
-who has "rotor issues".... (quote from female Autozone employee)
Old Jan 18, 2002 | 12:26 PM
RATEDR's Avatar
Will: yeah thats what I meant..OE rotors...not OEM factory, but replacement rotors that are the same as the stock ones....well, you get the point.
Thanks all.
Old Jan 18, 2002 | 12:35 PM
Blue Liquid's Avatar
New User
Is it possible that the Brembo (or any rotor) replacements can alter the braking ratio of the car, i.e. cause more of the braking to be done by the fronts leaving the rears with less work to do?
Old Jan 18, 2002 | 12:50 PM
junglistgsr's Avatar
Default Re: Anybody using the Brembo OEM ITR rotor? (Yellow R #01-0468)
not unless the rotors are larger in diameter if all you do is replace the OEM rotor with a new brembo blank.
i use the ITR sized re-drilled brembo blanks with ITR calipers on my GSR, (from fastbrakes) they are great so far...but i wish i had sprayed the hat of the rotor with flat black engine paint before putting them on because they looked so pretty when i got them now they are rusted as on the hat.
for the rear i have the fastbrakes 11.4" kit....he also makes this kit for the ITR i believe
Black R
Feb 16, 2011 12:38 PM
Weel
18
Oct 21, 2010 05:18 PM
supra360
May 13, 2008 09:09 AM
rjgerolaga
Mar 17, 2006 03:44 PM
Petah
Aug 14, 2002 08:45 AM
