90 std hatch...no tilt for steering wheel..wondering what parts i need for the tilt
Old Feb 18, 2005 | 05:04 PM
Gant's Avatar
Default 90 std hatch...no tilt for steering wheel..wondering what parts i need for the tilt
hi guys
i just installed my quick release on my momo steering wheel...sigh its kinda tilted up a little now..and with no tilt in my steering column it sux *** :/ i havent drove it much to get use to it so maybe thats why but it woudl be alot more better if the steering wheel was down more.
wondering what exact parts i need from another civic...will a crx work?
im assuming civic dx's and civic si's of course have tilt?
Old Feb 18, 2005 | 05:23 PM
Gant's Avatar
i just bid on a 91 si steering column, its from a hatch, but just wondering are civic and crx stereing columns the same...also how hard is this job?
Old Feb 18, 2005 | 05:34 PM
Malgerus's Avatar
Default Re: 90 std hatch...no tilt for steering wheel..wondering what parts i need for the tilt (Ba4)
CRX works, I used a CRX Si column in my hatch.
Only thing I had to do was to use my stock lock cylinder for the ignition.
Old Feb 18, 2005 | 05:38 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (Ba4)
Its fairly simple I swaped my si column over to my std model. I would think the crx si would be the same as the civic si.
You have to drop the colun and their is like 6 bolts then their is a 10mm bolt that holds the steering column in place at the bottom. The bitch part is removing the ignition. I drilled mine out and put two screws in it, which isn't really a good ideal but nobody will ever steal my car because its hidious. You have to remove all the plastic. If your a big guy you might want to remove your seat before you start doing it, so you have more space to work and it only takes 5minutes to remove. Its just a suggestion thats all.
Old Feb 18, 2005 | 05:40 PM
Gant's Avatar
yeah im going to remove my seat..sigh how many bolts hold the ignition in?
Old Feb 18, 2005 | 05:44 PM
HatchBox's Avatar
Skoobie no more...
I put the LX tilt steering colum in,
only problem i had was taking the ignition off
https://honda-tech.com/zerothread?id=1110469
Old Feb 18, 2005 | 05:48 PM
Gant's Avatar
thanx hatchbox..
i should have no problem taking it out i work at a dealership and one of the guys will help me out
so couple bolts will drop it right? then just switch over the ignition..question...does the igntion held up by anything? or just unbolt the column and it will go with it?
and plastic piece..by everything u mean everything besides the upper part of the dash?
Modified by Ba4 at 2:58 AM 2/19/2005
Old Feb 18, 2005 | 05:50 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (Ba4)
clamps the ignition unit (where you insert the key) to the steering colum.
Old Feb 18, 2005 | 05:51 PM
Gant's Avatar
in this picture..the ignition would go in that tan mark? lol next to where the steering wheel bolts onto?
Old Feb 18, 2005 | 05:55 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (Ba4)
see that silver part up by where the tilt lever is?
Well on the side there is a hole and you will see that it has a gear inside you have to turn the colum until the ignition fits into the gear.
It will make more sence when you hve your ignion switch off and you can put it up against the new colum
Old Feb 18, 2005 | 05:57 PM
Gant's Avatar
i c what u are talking about, its used for ignition lock right?
HatchBox's Avatar
Skoobie no more...
Default Re: (Ba4)
yup.
Old Feb 18, 2005 | 11:18 PM
Gant's Avatar
my friend said the tilt on these year civics arent even that much :/
Old Feb 18, 2005 | 11:32 PM
hahagasdcrx's Avatar
Default Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">my friend said the tilt on these year civics arent even that much :/ </TD></TR></TABLE>
Not really that much, but enough.
You may have to grind a slot on the backside of the ignition bolts, that way you can use a flathead screwdriver to unscrew it.
To remove, take off the steering wheel, unplug harnesses on back of the wiper and light levers. Unscrew the gauge cluster cover and remove ( makes things easier) and unscrew the signal/light control unit from the column. Remove the 4 14mm nuts from bottom side and the bolt at the floorboard(knuckle) that goes into steering column. Remove.
Install is the reverse as you probably know.
Old Feb 25, 2005 | 05:23 PM
Gant's Avatar
just got my steering column...qeustion...the tiilt mvoes up and down w/o even holding down the latch :/ did i get a fucked up one?
Old Feb 25, 2005 | 07:38 PM
kid-honda's Avatar
Default Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">just got my steering column...qeustion...the tiilt mvoes up and down w/o even holding down the latch :/ did i get a fucked up one?</TD></TR></TABLE>
Well something is wrong, it should hold.
This is a straight forward swap so I dont know what you would have done wrong?
Check the latch to make sure it can engage.
Old Feb 25, 2005 | 09:38 PM
Gant's Avatar
i hvaent installed it yet, i just got the column itself in the mail
gpdxtrm
13
Dec 28, 2007 08:10 PM
Grnade
Jul 16, 2005 08:02 AM
jaydm98
Sep 9, 2003 03:33 PM
