BARed EF's in CA: question about intake...can I go aftermarket/custm or stick with OEM?
Old Feb 18, 2005 | 03:39 PM
BlueShadow's Avatar
Default BARed EF's in CA: question about intake...can I go aftermarket/custm or stick with OEM?
Hi guys,
I'm gonna be getting my CRX with JDM B18C BAR'ed here in a few weeks and I had a quick question. Would the BAR guys care if I was to use a no name air intake tube with a cone filter on it? I figure that as long as I have the nipple that connects it to the valve cover then I should be fine. But I wanted to see how strict these BAR places are.
TIA
Old Feb 18, 2005 | 04:15 PM
Burlyirishdude's Avatar
Default Re: BARed EF's in CA: question about intake...can I go aftermarket/custm or stick with OEM? (BlueSha
I am going to just by a large Accord Air box and tube.
Old Feb 18, 2005 | 04:33 PM
Steemo's Avatar
yes they do care. You have to use something that is carb legal for the MOTOR not the car, or you have to have a stock airbox and tube.
Old Feb 18, 2005 | 05:27 PM
fourthgenhatchB17's Avatar
Hopefully Wes V. will chime in or u can PM him. I think he used a stock ef airbox with a stock DA tube?
Old Feb 18, 2005 | 06:19 PM
Wes V's Avatar
Just about the only way to do it is to use the stock air filter box and DA air tube! That's what I did when I got my (USDM) B18C BAR'd. (keep in mind that I'm running a Skunk 2 intake)
What's funny is that I just got in from the garage putting in an AEM cold air intake. It's the one that has the CARB number for the stock SI (with D series motor). Technically, it's not legal due to not being matched to the engine!!!!
The "hybrid" ones that AEM sells do not have a CARB number.
So, if the police pull me over, I've got the label on the intake. I doubt that a cop would know it's not legal, but a Referee would!!
Wes V
Old Feb 19, 2005 | 05:49 AM
BlueShadow's Avatar
thanks for the replies guys
I just thought I'd ask because I remember there was somebody with an RS Akimoto intake that passed the BAR. I'll just go ahead and rig up my stock DX box with a 90-93 Teg intake arm.
Old Feb 19, 2005 | 08:09 AM
Wes V's Avatar
You have to be careful when looking at what others have done. It's not that anybody is trying to lie about it, but they may post a photo that isn't exactly how the car was when they went into the referee!
Wes
Old Feb 19, 2005 | 09:26 AM
biggdogg's Avatar
i used a stock 92-95 airbox and a 96 ls tube . drop in k&n and works really well. you have to cut the mounting arm closest to the fender but the hole lines up for the bottom bolt behind the headlight . i also cut vents in the box in the front bumper to allow more air in .
crazyguy
Sep 10, 2007 08:04 AM
Zero2SixtySound
16
Jan 5, 2007 08:29 PM
helloDC2
Oct 20, 2005 09:20 AM
Integvalier
Aug 28, 2002 04:15 PM
AB16A2T
12
Jun 26, 2002 02:21 AM
