Ingredients for a fun weekend :)
Old Jan 18, 2002 | 10:57 AM
AssPenny's Avatar
Default Ingredients for a fun weekend :)
ATS 4.9 Final Drive, ATS Counter Shaft & JDM First
Excedy Clutch, Pressure plate & throw out bearing
I've got a spoon flywheel sitting at home that is also going on this weekend. Should be a blast. One thing is the fawking excedy pressure plate weights a ton. I don't know about other, but man that sucker is heavy. I've got all the other misc. parts that are needed also. Going to sears tonight to pick up the final tools needed. I'm going to take pictures of everything while we do it and post up a final impression along with what each gear redlines at and what the rpms drop to between each shift. This is going on a bone stock ITR (timing set to 18deg, everything else stock) so it should be interesting.
Thanks to Dave @ R&D and Mike @ IPS and Mike K at Naples Acura. Thanks for getting everything here on time and for all your help.
[Modified by AssPenny, 12:02 PM 1/18/2002]
Old Jan 18, 2002 | 11:02 AM
itr0032's Avatar
Default Re: Ingredients for a fun weekend :) (AssPenny)
Good times
Old Jan 18, 2002 | 11:08 AM
D's Avatar
D
NICE....
btw, i'm bringing along some of the honda super high temp urea based grease for the input shaft/throw out bearing... in case you don't have any..
D
Old Jan 18, 2002 | 11:17 AM
AssPenny's Avatar
Default Re: Ingredients for a fun weekend :) (D)
Funny you should say that, my gf is at Honda right now picking some up for me I'm also getting her to get some more MTF (got 3 quarts, but just in case) and some more bolts that hold the pressure plate to the flywheel, just incase also cause I know the Toda flywheel needs more.
Old Jan 18, 2002 | 11:21 AM
Mike M's Avatar
Founding Member
Goodluck on the install
Old Jan 18, 2002 | 11:22 AM
TypeR0149's Avatar
sounds fun
Old Jan 18, 2002 | 11:24 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: Ingredients for a fun weekend :) (TypeRmsm)
Good Luck?!?! GOOD LUCK?!?!??! Biatch, We-Todd-Did Racing will be in da hizouse for the install... oh...
yeah, Good Luck Craig.
We can do some pulls, I'll roll you first, then after the ATS, you should roll my *** big time
Old Jan 18, 2002 | 11:27 AM
AssPenny's Avatar
Default Re: Ingredients for a fun weekend :) (1SlowAssGSR)
Shi..., did you forget I have an ITR... ITR's can roll anything, yet alown a GSR
Have a safe drive down and see you tonight. D is leaving around 5pm, Jack is already down here, but has a dinner tonight (possibly).
[Modified by AssPenny, 12:27 PM 1/18/2002]
Old Jan 18, 2002 | 11:37 AM
D's Avatar
D
yeah, like they'll have them in stock.... maybe i'll swing by the junkyard real quick on my way out...
D
Old Jan 18, 2002 | 11:38 AM
b00st-0wnz's Avatar
Boy, you know you can't touch my 169whp/122.9ft-lb BEAST. Specially with my Faoons on dat bitch, she's tiiizziiiite.
Old Jan 18, 2002 | 11:40 AM
apexii's Avatar
Old Jan 18, 2002 | 11:42 AM
AssPenny's Avatar
That would be kick *** because I just spoke to her and they said that they could not look them up (she is at Honda) because its an Acura. I told her tell them its an IS and everything should fit. She is going to call me when she gets done to let me know, but it would be great if you could pick some up also. Better safe then sorry. I'll buy you a couple of lap dances for it
[Modified by AssPenny, 12:43 PM 1/18/2002]
Old Jan 18, 2002 | 11:43 AM
B2FiNiTY's Avatar
Nice. Why the JDM 1st?
Old Jan 18, 2002 | 11:48 AM
D's Avatar
D
i'm gonna head out now then...
call me if i'm needed..
D
Old Jan 18, 2002 | 11:49 AM
AssPenny's Avatar
Kewl beans, she just called and they did not have them. So if you could pick some up, I'll make it worth your wild. Thanks again.
Old Jan 18, 2002 | 11:52 AM
AssPenny's Avatar
Default Re: Ingredients for a fun weekend :) (B2FiNiTY)
The ATS & JDM counter shaft have a bigger OD (outer diameter) then the USDM so the USDM first will not fit on the ATS/JDM counter shaft. And you have to replace the counter shaft to match the ratio on the final drive. It was all included. It also came with the distancing collar and needle bearings.
[Modified by AssPenny, 12:53 PM 1/18/2002]
Old Jan 18, 2002 | 12:41 PM
STOLEN - ITR 98-0652's Avatar
Just remember guys...
LEFT HAND THREADS
Enjoy!
Old Jan 18, 2002 | 12:43 PM
AssPenny's Avatar
Default Re: Ingredients for a fun weekend :) (ITR 98-0652)
D is going to be here, I don't think he'll let us do that
Old Jan 18, 2002 | 12:50 PM
b00st-0wnz's Avatar
Yeah.. but we'll be drinking 40s!
Old Jan 18, 2002 | 12:54 PM
AssPenny's Avatar
I'm going to pick up some more beer tonight for tomorrow incase the 40's run out. What kind of beer do you like? I know Jason & D are Bud light, I like Mich light, Jack is a coors man. What do you want?
I'll bring the dremal too, lets see how much weight we can shave off the inside of the tranny, should be fun to do while lite up
[Modified by AssPenny, 1:54 PM 1/18/2002]
Old Jan 18, 2002 | 01:03 PM
Mike M's Avatar
Founding Member
Hide ALL The Big Fuggin Hammers
Old Jan 18, 2002 | 01:10 PM
figment's Avatar
New User
Do you need an alignment tool?
Old Jan 18, 2002 | 01:17 PM
B18CXr's Avatar
I'll F'ing drink all your Honda wrenching asses under the work bench....... Put your livers in a vise and clamp down on that light weight ***. Got to eat with some suppliers tonight but will crash the garage tomorrow early. Maybe late tonight.
SFL ****.
Old Jan 18, 2002 | 01:19 PM
AssPenny's Avatar
Default Re: Ingredients for a fun weekend :) (B18CXr)
SFL ****?!?!? You wish you were a SFL boy... where else can you work on your car at 1am and still be sweating in t-shirt and shorts?
I picked up a mini sledge for D today at home depot...
[Modified by AssPenny, 2:19 PM 1/18/2002]
Old Jan 18, 2002 | 01:20 PM
AssPenny's Avatar
Default Re: Ingredients for a fun weekend :) (figment)
Yea, its called the main shaft
