Installing AN fittings into valve cover
Old Feb 18, 2005 | 01:39 PM
allmotorhatch's Avatar
Default Installing AN fittings into valve cover
I have drilled and tapped the valve cover for the AN fittings. Should I use a silicone or a teflon tape on the threads? I have also seen them welded to the valve cover. What is my next step,or should I just leave them snug in the valve cover?
Old Feb 18, 2005 | 01:44 PM
drvfast's Avatar
Default Re: Installing AN fittings into valve cover (allmotorhatch)
I used a little bit of silicone. It has been working fine for me.
Old Feb 18, 2005 | 01:51 PM
ninesecrx's Avatar
Default Re: Installing AN fittings into valve cover (drvfast)
I would use hondabond on even locktight on the threads. When taking the hose off to remove the valve cover, sometimes those fittings like to back out from the valve cover. But then again, this is on a racecar that seems to have the valve cover off a million times!
Old Feb 18, 2005 | 02:08 PM
Default Re: Installing AN fittings into valve cover (ninesecrx)
Do you think a red loctite or more of a medium blue loctite?
Old Feb 18, 2005 | 02:15 PM
ninesecrx's Avatar
I would go with red loctite myself. I mean, it will still break loose if need be...
Old Feb 18, 2005 | 02:43 PM
Thankyou
Old Feb 19, 2005 | 08:03 PM
accordking's Avatar
Default Re: (allmotorhatch)
do you have access to a tig welder?
Old Feb 19, 2005 | 08:40 PM
turbo96wr's Avatar
you tapped but i would weld them and you won't have to worry about them leaking.
Old Feb 21, 2005 | 03:06 AM
Flamenco-T's Avatar
Default Re: Installing AN fittings into valve cover (turbo96wr)
You can use a teflon tape or paste. Make sure your adapter is an NPT adapter, this way the tapered thread will seal it better than an O-ring seal which may come loose under vibration.
stan
Old Feb 21, 2005 | 07:29 AM
h22 civic's Avatar
Default Re: Installing AN fittings into valve cover (Flamenco-T)
teflon paste dont over tighten!
Old Feb 21, 2005 | 08:24 AM
Default Re: Installing AN fittings into valve cover (h22 civic)
I ended up using the red loctite after I tapped the valve cover. I have had no problems yet, I also waited 24 hours for the loctite to dry. Thanks for all the input.
Old Feb 21, 2005 | 10:25 AM
philipwight's Avatar
I dont belive in teflon tape in a motor. If some of the tape gets into the oil system it could cause blockage, paste will usually just hang out where it was applied (in moderation).
Old Feb 21, 2005 | 10:51 AM
Flamenco-T's Avatar
Default Re: Installing AN fittings into valve cover (philipwight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philipwight &raquo;</TD></TR><TR><TD CLASS="quote"> I dont belive in teflon tape in a motor. If some of the tape gets into the oil system it could cause blockage, paste will usually just hang out where it was applied (in moderation).
come on Phillip...you need to learn to put a teflon tape on hahaha LOL
JK
stan
Old Mar 8, 2005 | 09:46 AM
dave@sweetperformance's Avatar
AN fittings have a straight thread. You should use an O ring or Stat O seal on them.
I'm a teflon tape hater on any NPT thread as it always seems to end up where I don't want it. (oil pumps and injectors, you get the idea) If you are going teflon to seal treads use the past as it stays put better.
