help new swap blows one code
Old Feb 18, 2005 | 10:53 AM
88cerx's Avatar
Default help new swap blows one code
ok so i got a b18b swap converted to obd0 in my 88 crx si the only code is 4 long and 3 short then repeats i heard ist a fuel problem but not sure it has stock pump and fpr please help fast
Old Feb 18, 2005 | 10:54 AM
EP3_05's Avatar
Default Re: help new swap blows one code (88cerx)
43 is the fuel pump. I have seen alot of people with LS swaps get this code. My only advice is try clearing the codes and see if it goes away. Does the car run?
Old Feb 18, 2005 | 11:00 AM
88cerx's Avatar
Default Re: help new swap blows one code (91civic)
yes runs good not awesome ecu is weak comparred to the 94 cpu that is supose to be yousing
Old Feb 18, 2005 | 11:15 AM
manson's Avatar
what ecu are you using now?
more than likely you have the OEM pump and FPR... i would run through a helms and see what they say to test for when getting that code...
sorry i can't help more.
<search begins <---
Old Feb 18, 2005 | 11:28 AM
manson's Avatar
Default Re: help new swap blows one code (manson)
found this post in the integra forum.
https://honda-tech.com/zerothread?id=1145894
may be a bad o2 setting it off... after search google some other people were given that suggestion as well.
you may want to PM the topic starter from that link and ask if it was solved or not.
Old Feb 18, 2005 | 11:37 AM
88cerx's Avatar
i have crx pump 90 b18a feul rail and fpr on a 90 ls pr4 ecu obd0 on a obd1 b18b block/head
Old Feb 18, 2005 | 12:51 PM
88cerx's Avatar
bump
Old Feb 18, 2005 | 07:58 PM
88cerx's Avatar
bought o2 sensor will put in when it gets here will post turnout
IHEARTMYHONDA91
Nov 3, 2006 10:08 AM
neuerasd9
Feb 16, 2006 01:58 PM
slowbluhatch
11
Apr 15, 2005 12:13 PM
88bottlefedcrx
Jan 29, 2004 03:12 PM
crxhfpower123
Nov 8, 2003 01:48 PM
